most whp on stock compression(b18c1)
Old Sep 17, 2003 | 12:54 PM
JunIntegra's Avatar
Default most whp on stock compression(b18c1)
also please explain what bolt ons will get me to there
Old Sep 17, 2003 | 02:15 PM
JunIntegra's Avatar
Default Re: most whp on stock compression(b18c1) (JunIntegra)
anyone know?
Old Sep 17, 2003 | 05:33 PM
96dc2's Avatar
Stock compression? Or stock block? GZR4DR has made over 200 on a stock B18C1 block. But it wasn't stock compression.
Old Sep 17, 2003 | 06:15 PM
Viorent Grip! EG's Avatar
Default Re: most whp on stock compression(b18c1) (96dc2)
how is a stock b18c1 block without stock compression still considered a stock block?
are you referring to a thinner head gasket for a little bump? assuming that its a usdm motor (c1) .... i'm under the impression that a stock block yeilds that it is a block that has not been touched either for reinforcement or modification....
Old Sep 17, 2003 | 06:25 PM
BolivianDc2's Avatar
Default Re: most whp on stock compression(b18c1) (VG-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VG-EG &raquo;</TD></TR><TR><TD CLASS="quote">how is a stock b18c1 block without stock compression still considered a stock block?
are you referring to a thinner head gasket for a little bump? assuming that its a usdm motor (c1) .... i'm under the impression that a stock block yeilds that it is a block that has not been touched either for reinforcement or modification....</TD></TR></TABLE>
A block could be stock with higher compression by milling the head and/or using a thinner headgasket. That is what he probably means, all headwork, no bottom end work.
Old Sep 17, 2003 | 06:30 PM
Casey's Avatar
Default Re: most whp on stock compression(b18c1) (Bolivianstrtwpn)
im making 182/131 on a stock jdm gsr block. no milling or thin headgasket. I do believe 200+ is possible with milling and headwork
Old Sep 17, 2003 | 07:00 PM
Eyewitness's Avatar
Default Re: most whp on stock compression(b18c1) (Casey)
200whp is possible on stock or near stock compression....most poeple do not build there motors effectively enough to reach this on stock compression though...most people piece together there motor over time....doesnt always work out too well
Old Sep 17, 2003 | 07:14 PM
96dc2's Avatar
http://www.geocities.com/gzr4dr/. This guy's power came from his headwork. Of course tuning is key also.
Old Sep 18, 2003 | 03:27 AM
JunIntegra's Avatar
yes my post says "stock compression" not block. meaning nothing has been molested.
Old Sep 18, 2003 | 04:04 AM
Casey's Avatar
you can molest the head and not mess with compression(static at least) you should have specified bolt ons.
demian22
Feb 28, 2008 10:34 AM
KiNG $h!t
49
Jan 7, 2008 04:39 PM
eddie1681
Jun 19, 2002 09:39 PM
