clutch cable to short for b series swap
Old Sep 17, 2003 | 12:01 PM
smashed4thgen's Avatar
Default clutch cable to short for b series swap
what can i do to get extra lenth outta my clutch cable.?its only like a inch to short..
Old Sep 17, 2003 | 12:05 PM
Phatwhippin_CRX's Avatar
Default Re: clutch cable to short for b series swap (smashed4thgen)
use one from a 90-93 teg
or just disregard the bracket that it runs through and you might get that extra inch you need....
Old Sep 17, 2003 | 08:38 PM
Default ?
disregard??? i was thinkin about a way to modify the bracket...
Old Sep 18, 2003 | 10:21 AM
HandCommand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smashed4thgen &raquo;</TD></TR><TR><TD CLASS="quote">what can i do to get extra lenth outta my clutch cable.?its only like a inch to short..
This has been covered MANY, MANY, times before. You dont need to buy a new clutch cable. Just UNBOLT the bracket ( 2-12mm bolts), adjust the threaded **** all the way loose (up), put the cable in the bracket first, then attach to the tranny lever, then RE-BOLT the clutch cable bracket back up. Then adjust the threaded **** as necessary.
I'd rather see you spend money on the right throttle cable instead, ( so it pulls your throttle 100%) rather than wasting your money on a clutch cable that is not needed.
I've done countless number of Bseries swaps into EF's and NEVER had to replace the CLUTCH cable.
Old Sep 18, 2003 | 01:51 PM
zCivic's Avatar
Default Re: clutch cable to short for b series swap (HandCommand)
I never changed the clutch cable on a ZC swap, Z6 swap, B16 or my ls-vtec. It will work. With my Xtreme p-p I had to use the cherry picker hook on the lever to pull it up so I could get the end in the lever
Old Sep 19, 2003 | 07:50 PM
YumVTEC's Avatar
Default Re: clutch cable to short for b series swap (zCivic)
i have tried both the stock clutch cable in my Std. and the cable from the wrecked 92 gs-r that I bought, and *BOTH* are too short. i'm going to go outside right now and unbolt the bracket and try it that way, but i don't think it's going to work...
Old Sep 19, 2003 | 08:00 PM
bryant's Avatar
Default Re: clutch cable to short for b series swap (YumVTEC)
You have to extend it all the way out the plastic screw to the top. then put it in. Its sorta a PITA but it can be done. Stop being such a *****.
Old Sep 19, 2003 | 09:19 PM
SiR Kid's Avatar
New User
Use a floor jack and a block of wood to push up on the clutch arm, and then install the cable.
It'll work fine, trust me.
Old Sep 19, 2003 | 09:42 PM
Ef Whore's Avatar
Default Re: clutch cable to short for b series swap (SiR Kid)
Using the stock clutch cable is possible...but you will have no adjustment whatsoever. It does work though. A 90-91 teg cable is the desired one.
Old Sep 19, 2003 | 11:42 PM
90civichbsi's Avatar
Default Re: clutch cable to short for b series swap (Ef *****)
im using the stock cable as well, i had to do the same thing as the rest of them, and unbolted the bracket etc. etc.
Old Sep 20, 2003 | 12:09 AM
solman74's Avatar
Amen, I agree here. I just swapped mine and everything but the throttle cable swaps over. A buddy gave me his. I bolted that in no issues and away I go. Lot's of small stuff to get in your way. clutch cable does not need to be replaced. I have full clutch and flywheel replaced and still no issues. All that I did was put more slack in the cable and was able to thread it through. Then tightened it back up. Way to easy. Took 3 seconds to install. No bolts were harmed during this process. he he he.
