Aircraft Stripper to remove sparyed paint on my wheels...overkill?
Old Sep 17, 2003 | 11:12 AM
alfaaay's Avatar
Default Aircraft Stripper to remove sparyed paint on my wheels...overkill?
A while back, I wanted to see what a set of rims of mine would look like if it were gunmetal, so I sprayed them gunmetal with the wheel spray that can be found at any auto parts store. Now that I want to take that off, should I be using aircraft stripper or will normal paint remover be just fine? I ask because after reading horror stories like this one https://honda-tech.com/zerothread?id=563683, I'd rather only use air craft stripper as a last resort. Has anyone sprayed their wheels and then removed the paint? How did you? Also, if I do decide to use the aircraft stripper, will it eat through my tires, masking tape, or the stickers on the wheels?
Here's a picture of the wheels, I want to take the paint off only the inner lip, and I don't want the stickers to be eaten, or the tires, etc.....
I appreciate any and all advice/help, thanks!
Old Sep 17, 2003 | 11:15 AM
ebelp's Avatar
Default Re: Aircraft Stripper to remove sparyed paint on my wheels...overkill? (alfaaay)
You'll be fine using the aircraft stripper on your wheels and tires. You'll be scrubbing your wheels for a week if you use normal paint remover. Just spray the aircraft stripper on, wait a couple minutes, and spray it off with a hose. It never has to get near your skin. I've used that stuff to polish the wheels on my Yamaha, and had the aircraft stripper all over the tires and it did nothing.
Old Sep 17, 2003 | 12:09 PM
phantom_sol's Avatar
where would you get this stuff?
Old Sep 17, 2003 | 12:43 PM
IgniteTeg's Avatar
Default Re: (phantom_sol)
your local home depot sells em. Thats where I got mine. They have so many of that. The spray kind and the paint one.
WhiteGSR95
Paint and Body
Apr 7, 2012 07:01 PM
dth0ng69
Nov 8, 2009 11:43 AM
ekcivic9
Aug 2, 2005 12:48 PM
SingleCamIam
Jun 23, 2005 08:53 AM
OneCleanLS
Apr 25, 2005 05:26 PM
