koni reds how do u kno if there adjusted right
Old Sep 17, 2003 | 07:39 AM
-slow ej-'s Avatar
Default koni reds how do u kno if there adjusted right
i just bought a set of koni reds..and there adustable but when i read the instructions it confuses me cuz i dont kno how to adjust the shock...so when i push down and turn it how do i kno its being adjusted? what if i turned it to much and i didnt kno?
Old Sep 17, 2003 | 10:44 AM
eHoward's Avatar
Default Re: koni reds how do u kno if there adjusted right (-RsINtEg-)
My dad's alfa has red's so the process should be similar. They should click; not audible but mechanical if you understand that. Don't try to go past the last click though or you could damage them.
When you install it on your car and drive you should be able to feel a difference between full damping and under-damping if you are sucessfully adjusting. You can do one at a time. Don't worry, you wont damage anything by driving around with different rates.
Post how you like em after you figure out tuning . . . I'm debating between specials and sports for my rex. I didn't realize that they didn't adjust on top of the shock tower like my blues or strut konis. That's something to think about.
Old Sep 17, 2003 | 04:39 PM
-slow ej-'s Avatar
Default Re: koni reds how do u kno if there adjusted right (eHoward)
i adjusted them alreddy according to what koni said when i called them and they ride fine...i think i might take em out and adjust them a lil more so it can be softer but im afraid that if i do that then i might blow the shock..and im not tryin to have that happen again..so ill juss see what happens and let it be for now...thanks tho
redDAinteg
Suspension & Brakes
19
Sep 24, 2009 03:46 PM
prime_suspect
Suspension & Brakes
11
May 15, 2008 01:41 PM
pcorad
Jul 30, 2002 12:40 PM
95hbMatt
Jun 24, 2002 10:22 PM
taytay333
Mar 25, 2002 09:07 PM
