What kind of WHP to hit 11.99 on 225/50-15 DR's ?
For these two cars.
2300lb Hatch w/Driver . . . Hatch has yet to run. *Friday*
2850lb GSR w/Driver . . . With 280-300 this GSR hit 12.7@113 w/2.0 on DR's
Thanks Guys.
Thanks Guys.
2300lb hatch
240-250whp NA
340-360whp Boost
2850lb gsr teg
250-260whp NA
360-400whp Boost
My friend's gsr teg ran 11.90@119 with 380whp but on slicks.
I think it will be hard to grip on boost on those radials. There are a few 11 second turbo street tire cars and they are all making above 400whp!
240-250whp NA
340-360whp Boost
2850lb gsr teg
250-260whp NA
360-400whp Boost
I am with you on this ryan!
i just went 12.4 @112 on BFG's sunday.
I am also looking to go 11's on a street radial.
I just tuned the car on race gas and good boost #'s
so i guess saturday we will see what i can do.
also guys i am using a 215/60/14 BFG.
Brian
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettols »</TD></TR><TR><TD CLASS="quote">you goin' to famoso this friday??</TD></TR></TABLE>
I will be there.
I will be there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">
2300lb hatch
240-250whp NA
Hmmm, I highly doubt an N/A car would run 11.99 > with Drag Radials weighing 2300lbs.
2300lb hatch
240-250whp NA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">
Hmmm, I highly doubt an N/A car would run 11.99 > with Drag Radials weighing 2300lbs. </TD></TR></TABLE>
don't doubt.
don't doubt.
Smarter than you
not sure about NA but on boost in a 2300lb car you should be able to do it w/ 360whp, the right set up, and a good driver. No one in the 11's so far is running a proper turbo set up for street tires. theres definitly room for improvement.
my 12.8 only took about 260whp wieghing 2620lbs and when I made the pass it didn't even feel like a good pass. my friends 520whp 2600lb hatch(hes a big guy and the car is full everything) went 12.3 @ 132 and then he turned the boost down to 13lbs and hit 12.1 @ 121. just goes to show its not all about power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del »</TD></TR><TR><TD CLASS="quote">good friend of mine just went 12.00 on some BFG's
his car has over 500+ to the wheels</TD></TR></TABLE>
yea, yea, i wish it was making that much then. Making alittle over 400 spinning my *** off and the car crapping out again at the 800' and half throttle in 5th. The car went 12.0@115 on those bfg's. I see some 11.90's maybe 11.80's on radials out of my car.
Also, my car weighs 2625 with me in it. If I turn the boost down some I think the car might actually go a little faster, but what's the fun in going down. Anyone know the current record for fwd honda on street tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo »</TD></TR><TR><TD CLASS="quote">Yea, i'd love to take a look and get a set of those. I love thier slicks, I can only imagine the quality of thier radials.</TD></TR></TABLE>
m&h street slick, has a slick compound, comes 235/60/15 and has a 25.4 overall diameter. thats over a 5" sidewall. that would be nice.
i went 12.4@128 on 255/50/16's on my 1st pass. I still want to break the 11.88 record myself. I just never made it back to the track on radials again. Remember the guy with the most hp will not break the 11.88 record thats for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote"> Remember the guy with the most hp will not break the 11.88 record thats for sure.</TD></TR></TABLE>
Yep . . We want to hit 11.99 with 350whp & 1.7 60ft
In a 2800lb car?
</TD></TR></TABLE>In a 2800lb car?
i dont think its possible to cut a 1.7 on drag radials fwd. enough rwd cars have trouble cutting those 60fts. shoot for a 1.999 and you'll go 11's with the right setup. when i went 12.4@128 i cut a 2.4 60ft so imagine what you can do with a 2.0 60ft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston »</TD></TR><TR><TD CLASS="quote">
In a 2800lb car?</TD></TR></TABLE>
In a 2300lbs car.
In a 2300lbs car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote">i dont think its possible to cut a 1.7 on drag radials fwd. enough rwd cars have trouble cutting those 60fts. shoot for a 1.999 and you'll go 11's with the right setup. when i went 12.4@128 i cut a 2.4 60ft so imagine what you can do with a 2.0 60ft.</TD></TR></TABLE>
Cut a 1.89 2 weeks ago with 205/50-15 BFG's :rockon:
That's with a 2800lbs car, Open Diff and 7000 rpm Launch.
Looking for a 1.79 > with 2300lb car, Quaife, Drag Springs in rear and 7000 rpm launch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling »</TD></TR><TR><TD CLASS="quote">1.8 60ft is really good
Those BFG's get outta the hole...
