exhaust back pressure
Old Sep 17, 2003 | 05:51 AM
DOHCon15s's Avatar
Default exhaust back pressure
Ok so i have a 95ls with I/H/E no p/s and new sparks and wires, and my apexi cat back is 2.36" in diameter and it pops sometimes between shifts on daily driving , and i was wondering if i gutted the cat would it make it worse and ever since i put on my exhaust and everything else my idle has dropped like to 400 RPMs
Old Sep 17, 2003 | 07:01 AM
DOHCon15s's Avatar
Default Re: exhaust back pressure (DOHCon15s)
HELP
Old Sep 17, 2003 | 07:35 AM
DOHCon15s's Avatar
would there be too much back pressure if i put on a cat that is gutted with a 2.36 inch exhaust
Old Sep 17, 2003 | 08:56 AM
BolivianDc2's Avatar
if you gut the cat it will be worse, the reason why it pops is because of the bottle neck of the piping. You don't like the popping?
*edit, didnt read the part about your idle, maybe its not the exhausts fault
Old Sep 17, 2003 | 01:21 PM
GSRacer1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCon15s &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i have a 95ls with I/H/E no p/s and new sparks and wires, and my apexi cat back is 2.36" in diameter and it pops sometimes between shifts on daily driving , and i was wondering if i gutted the cat would it make it worse and ever since i put on my exhaust and everything else my idle has dropped like to 400 RPMs</TD></TR></TABLE>
I have the same problem. I still dont understand what makes that pop after almost every gear if i change the gear fast it makes that pop, but why?
Old Sep 18, 2003 | 08:01 AM
SOHC_MShue's Avatar
bump for my friend Yea my civic is idling low as **** too. Can just boltons cause this?
jdmhatch1
20
Jan 5, 2008 05:14 PM
untitledsn41
Aug 30, 2004 04:01 PM
matttegra
Sep 16, 2003 04:53 PM
Pfieff
Sep 12, 2003 01:59 PM
whiteb16a
Oct 15, 2001 06:00 AM
