Flywheel weight
Old Sep 16, 2003 | 05:00 PM
twuelfing's Avatar
Default Flywheel weight
I need a confirmation on the weight of the flywheel in the ITR.
Old Sep 16, 2003 | 05:01 PM
vtec.dc2's Avatar
Default Re: Flywheel weight (twuelfing)
somewhere along 15lbs
Old Sep 16, 2003 | 05:06 PM
twuelfing's Avatar
what is your opinion of this product?
http://cgi.ebay.com/ebaymotors...07401
i dont want a radical difference, but i dont want to have to take my flywheel to get machined when i am changing my clutch. and this seems like a small enough difference not to cause a problem.
Old Sep 16, 2003 | 06:20 PM
v00tecsi's Avatar
Mine weighed in at about 14-15lbs just like vtec said. (more towards the 14lb mark.)
Old Sep 16, 2003 | 06:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: (twuelfing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i dont want a radical difference, but i dont want to have to take my flywheel to get machined when i am changing my clutch. and this seems like a small enough difference not to cause a problem.</TD></TR></TABLE>
If that's what you're after, the StreetLite will be fine, but my personal choice between the two would be the ProLite.
Old Sep 16, 2003 | 10:57 PM
SoCal ITR's Avatar
Default Re: (Padawan)
I doubt you'll notice 2 or so pounds... but I have the prolite and I like it.
Old Sep 16, 2003 | 11:14 PM
jsk62's Avatar
im pretty sure itr flywheel is 14, and gsr is like 18
Old Sep 17, 2003 | 02:23 AM
Tyteteg119's Avatar
Default Re: (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">I doubt you'll notice 2 or so pounds... but I have the prolite and I like it. </TD></TR></TABLE>
You have to understand the concept of lightening the FW. 2 pounds off the FW is Like Lightening the Car by 200 pounds During Acceleration. That's A big Difference. The Stock FW is 6.9kg which is 15 pounds
Old Sep 17, 2003 | 08:24 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twuelfing &raquo;</TD></TR><TR><TD CLASS="quote">what is your opinion of this product?
</TD></TR></TABLE> the ACT Streetlite is fine but the ACT Prolite at 8.8# is what I have been using this year and it is excellent and has caused NONE of the commonly mentioned theoretical downsides.
Old Sep 17, 2003 | 08:27 AM
SoCal ITR's Avatar
Default Re: (Tyteteg119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyteteg119 &raquo;</TD></TR><TR><TD CLASS="quote">You have to understand the concept of lightening the FW. 2 pounds off the FW is Like Lightening the Car by 200 pounds During Acceleration. That's A big Difference. The Stock FW is 6.9kg which is 15 pounds</TD></TR></TABLE>
Do you have a lightweight flywheel?
I do and I can tell you right now that acceleration is not noticibly different at all (at least on my car), in fact, I'd bet it's about identical in my opinion (based on street driving and 1/4). Rev matching is much nicer though.
Also, it depends on where on the flywheel the weight was taken from, you can't just make a baseline claim that 2 lbs = 200 lbs.
So using either argument, I believe you are incorrect.
Modified by SoCal ITR at 10:24 AM 9/17/2003
Old Sep 17, 2003 | 08:53 AM
GokuSSJ4's Avatar
im running tilton flywheel which is around 8lbs (a nice difference in accelaration) but toda , or even excedy are some nice flywheels ....
sl0waccord
Feb 13, 2012 08:52 AM
ajmj
Feb 9, 2005 11:59 AM
97F22B2
Sep 23, 2003 12:25 AM
Integra_B18B
Feb 23, 2002 04:44 PM
