major wheel hop problem.... please help
Old Sep 16, 2003 | 04:10 PM
tallblondkid's Avatar
Default major wheel hop problem.... please help
i have a 95 civic coupe, with a D16Z6. unfortunatly i have 17"rims. but when i launch, even as low as 3000 rpms, my wheels just hop away. i need traction, what do i do
Old Sep 16, 2003 | 06:05 PM
AlphaKennyWun's Avatar
Default Re: major wheel hop problem.... please help (tallblondkid)
try launching at a higher rpm. One thing ive learned by going different levels of N/A through turbo is that the more power i have going to the wheels, the less wheel hop i have. The trick to a good launch is hazing the tires.
Old Sep 16, 2003 | 06:14 PM
99blackcivicSi's Avatar
smaller wheel nice sidewall traction bars
Old Sep 16, 2003 | 06:48 PM
MikeExt's Avatar
New User
Default Re: major wheel hop problem.... please help (99blackcivicSi)
Your engine is stock and you have that problem? If you really want to cure it, then get polyeurathane? engine mounts and tranny mounts. I have them, and haven't gotten wheel hop yet with over 200whp.
Old Sep 16, 2003 | 07:27 PM
b18cu's Avatar
Default Re: major wheel hop problem.... please help (MikeExt)
I think wheel hop is due to either too stiff of suspension, or just not enough power.
Old Sep 17, 2003 | 10:36 AM
H22uner's Avatar
Check tire pressure -- too low of pressure can cause hop
or
As people have said before check to make sure you don't have a worn or broken tranny or engine mount.
Old Sep 17, 2003 | 05:04 PM
92HB_HB's Avatar
Default Re: major wheel hop problem.... please help (b18cu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cu &raquo;</TD></TR><TR><TD CLASS="quote">I think wheel hop is due to either too stiff of suspension, or just not enough power.</TD></TR></TABLE>
i beg to differ.. wheel hop is usually caused by a poor suspension setup... and less power won't cause it either... launching technique is also a big factor..
if you're hoppin, let off the throttle, else you'll brake something....
Old Sep 19, 2003 | 06:57 AM
92h22a's Avatar
Try these from Totem or Jim Fab make these too.
I know theso are on back wards but it has since been corrected.
Old Sep 19, 2003 | 07:43 AM
ImportechPerformance's Avatar
Default Re: major wheel hop problem.... please help (92h22a)
Dude just sell those 17's and go with 15's and some nice rubber maybe some Falkens Azienas...that should help a lot!
Then if you want to be more serious i would get some stiffer motor mounts
Then if you do want to go all out get the tracion bars...but thats only if you have some more power wont be needed on a stock d-series...
BUT seriously get rid of those 17's and go out and get some cheap light wieght! 15's
Old Sep 19, 2003 | 08:15 AM
95c1v1cs1's Avatar
Default Re: major wheel hop problem.... please help (H22uner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22uner &raquo;</TD></TR><TR><TD CLASS="quote">Check tire pressure -- too low of pressure can cause hop</TD></TR></TABLE>
I lowered my pressure and got less wheel hop.
Best thing you can do to get reid of wheel hop is Traction bars, Ureathane Motor Mounts and Bushing, suspension, and alignment.
If you were to only get one of those... GEt the Traction Bars.
Another Option is Slicks. I think you would get reid of any wheel hop with Slicks at your power.
civicsaremean
18
Jul 23, 2007 11:17 AM
Blacklabel182
Apr 5, 2007 05:40 PM
mrEM1
15
Apr 7, 2006 10:56 AM
B16Civic93
Oct 22, 2004 07:12 PM
brega3
Apr 22, 2003 08:07 PM
