Speedometer cable help b16
Old Sep 16, 2003 | 03:36 PM
Dorifto13B-T's Avatar
Default Speedometer cable help b16
where does the speedometer cable plug in on the tranny?????? helppp.. if you have pics thatd be ****** awesome.
Old Sep 16, 2003 | 04:22 PM
Redline130's Avatar
Default Re: Speedometer cable help b16 (wyt r1ce)
It plugs into the vehicle speed sensor which is located to the rear of the tranny. There should be a short, round tube sticking up. Just slide the cable in and secure it with a clip.
Old Sep 16, 2003 | 04:38 PM
90crxb16a's Avatar
Default Re: Speedometer cable help b16 (Redline130)
On my B16 its on the back/top of the tranny. IF you look down on your engine to the left of the intake manifold you should see a hole. Mine is secured on by a bolt not a clip. Its a bit hard to see, use a flash light
Old Sep 16, 2003 | 05:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
if pic does not show try clicking here:
http://mediaservice.photoislan...2.jpg
Old Sep 16, 2003 | 05:34 PM
Default Re: Speedometer cable help b16 (88DXCRX)
hell yeah i plugged it in and it works. yo 88, whats with the hose goin on that pic. is that required cause i dont have that.
Old Sep 16, 2003 | 05:43 PM
88DXCRX's Avatar
The vehicle it came from had something called
"speed-assisted power-steering"..
It is a small pump that adds pressure to the power steering system as the speed increases.
I looped the hose and filled it with power steering fluid to keep it lubricated
so it does not seize up.
Old Sep 16, 2003 | 05:44 PM
nice. thanks for yalls help im all fixed.
swint2007
Apr 3, 2010 11:14 AM
92 CIVIC HATCH VX
Apr 5, 2006 03:41 PM
jdm_lover
Nov 5, 2004 12:22 AM
tencan
May 5, 2004 11:03 AM
