Prelude shifter and cables in 4th gen...need help
Old Sep 16, 2003 | 02:13 PM
H22assbusa's Avatar
Default Prelude shifter and cables in 4th gen...need help
WEll i bought everything for less the $60 but i have the shifter plate in my car but only 2 of the 4 bolts that attach the shifter and plate to the chasis match. What should i do about the other two. If i don't get it lined up perfect will it effect by cars shifting. I also have some extra shifter and cables for $80 shipping included.
Old Sep 16, 2003 | 03:11 PM
f22a's Avatar
i have never heard of having to use the plate...
do you have a 1990? also keep in mind that if you have the 97+ prelude shifter assembly, it is a different shape and size, and wont bolt in correctly or look as clean, but will still work.
Old Sep 16, 2003 | 03:32 PM
fizzbob7's Avatar
Default Re: (f22a)
what are you doing.....short shifter install or just a swap....either way, accord parts work best
Old Sep 17, 2003 | 12:46 AM
H22assbusa's Avatar
I'm using a 92-92 prelude shifter, plate, and cables. I tried installing the shifter and part the connects to the cable on the left to the shifter to the accord plate but the part that connects to the left cable did fit properly. Should i only install the prelude shifter and use the accord part that connects to the left cable. I do like how the prelude plate and shifter sits alot lower though, would it cause any major problems?
Old Sep 17, 2003 | 07:13 PM
f22a's Avatar
i'm stumped, man
if it works with the prelude plate and everything, like i said before, it wont install clean but will still work.
but i'm stumped
Old Sep 18, 2003 | 05:49 AM
v4lu3s's Avatar
RTFM
last one i did had teh lude shifter assembly complete with 4th gen accord cables and it worked fine without issues.
i took out the rubber bushings on the rear of the shifetr assembly i think though.
Old Sep 18, 2003 | 06:44 AM
H22assbusa's Avatar
UPDATE! well i had to slide the plate down and used the accord bushing but removed the metal inserts on the inside of the plate and it all came together perfect and a clean install.
bigsnorlax
Dec 9, 2009 07:47 PM
H22isnotabigblock
May 29, 2007 04:14 PM
ilovemydc5
Jan 20, 2007 01:03 PM
flight50
Sep 26, 2006 09:43 PM
stRodda
Sep 22, 2003 12:23 PM
