When to change your timing belt .
Old Sep 16, 2003 | 02:02 PM
shannon's Avatar
Default When to change your timing belt .
At how many miles do I have to change the Timing belt on my 1996 b18b1 engine?
Old Sep 16, 2003 | 03:47 PM
Dancing is Forbidden's Avatar
Default Re: When to change your timing belt . (shannon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shannon &raquo;</TD></TR><TR><TD CLASS="quote">At how many miles do I have to change the Timing belt on my 1996 b18b1 engine? </TD></TR></TABLE>about now its more of a security issue. If you don't know when the last time it was done was, change it. I would change them every 80000 miles.
Old Sep 16, 2003 | 03:51 PM
blackeg's Avatar
Default Re: When to change your timing belt . (EF9_SiR)
im pretty sure its 90,000 miles
Old Sep 16, 2003 | 04:25 PM
TheDingo8mybaby's Avatar
I try to do it at least 60k...expecially on a motor without valve clearance.
Old Sep 16, 2003 | 07:06 PM
shannon's Avatar
Default Re: (TheDingo8mybaby)
ttt
Old Sep 16, 2003 | 07:07 PM
poison's Avatar
Default Re: (shannon)
Usually about every 90,000 miles on a stock motor.. Along with valve adjustments
Old Sep 16, 2003 | 07:12 PM
NA gs-R 05 C
Guest
Posts: n/a
around 70k-ish miles is good.
Old Sep 16, 2003 | 07:16 PM
whatVTEC's Avatar
Default Re: When to change your timing belt . (NA gs-R 05 C)
under "normal" operating conditions..90k
If you're thrashing on you motor or running it hard, I would do it sooner.
AccordEX1991
Honda Civic (2001 - 2005)
26
Dec 11, 2007 02:01 PM
square_1
13
Mar 7, 2007 10:10 AM
intgraCA
Oct 5, 2006 07:54 AM
autoground
Mar 30, 2005 06:19 PM
wm5holla
Apr 26, 2003 12:42 PM
