which clutch would work
Old Aug 21, 2001 | 11:14 PM
B16Vtec's Avatar
New User
Default which clutch would work
A friend of mine has a 2nd Gen. integra LS 90 or 91 he swap in a 3rd Gen. GSR motor everything working fine. Except the clutch won't go in gear he has the GSR clutch in right now. What clutch should he use? LS or GSR?
Old Aug 22, 2001 | 01:02 AM
nugget8000's Avatar
New User
Default Re: which clutch would work (B16Vtec)
I don't know if the clutches are the same in the 2nd gen as the third, but I believe all 3rd gens use the same disk, just a different pressure plate for each engine. I am not sure of how much each pressure plate differs in strength though. What do you mean by the clutch won't go into gear?
Old Aug 22, 2001 | 08:12 AM
rwong's Avatar
New User
Hello,
What transmission is your friend running? The GSR tranny or the factory LS tranny.
Old Aug 22, 2001 | 08:41 AM
B16Vtec's Avatar
New User
Default Re: which clutch would work (rwong)
Oh I forgot my friend using the LS tranny
demon666999
Mar 22, 2004 10:57 AM
the.hamburglar
Mar 2, 2004 09:33 PM
3rdGteg
Nov 5, 2002 05:02 PM
S13 slide
Oct 9, 2002 09:26 AM
