Help...need ITR ECU pinouts
Anyone with a Helm manual happen to know the following pinouts for the 2000 ITR ECU's
TPS:
MAP:
IAT:
VTS:
VTM:
Can you state the connector, pin number, and color of the wire?
For example-
TPS: Connector C 31P, pin 27, red/blk
Thanks
TPS:
MAP:
IAT:
VTS:
VTM:
For example-
Thanks
Here you go Zip, hope it helps...
Austin
TPS: connector 31P #27 RED/BLK
MAP: connector 31P #17 WHT/YEL
IAT: connector 31P #25 RED/YEL
VTS: connector 25P #12 GRN/YEL
VTM: connector 31P #10 BLU/BLK
Austin
Wow, fast reply! Thanks a bunch Austin.
I just checked my SI pinouts to the ones you posted, they're exactly the same the as the ITRs. Hmmmm.....weird.
[Modified by zip, 11:49 PM 8/21/2001]
Austin
Ricky Unhinged
Apr 8, 2018 07:34 PM
jdm_xsi206
Sep 21, 2011 09:03 AM
B serious
Mar 12, 2008 08:27 PM
WannaHonda
Aug 5, 2004 01:22 PM
