91 si conversion dx cuts out at 3000!!!! help
Old Sep 16, 2003 | 09:25 AM
WCI's Avatar
WCI
Default 91 si conversion dx cuts out at 3000!!!! help
The dx wiring was shorted somewhere so I switched the inner and outer harness with one from an si. Car starts but I cant find the plug for the fast idle and I also am not getting any power to the fuel pump. I jumped it to get it running but at partial throttle it wont rev over like 3k. Ideas? already tried ignition and cam timing.
Old Sep 16, 2003 | 08:52 PM
WCI's Avatar
WCI
Default Re: 91 si conversion dx cuts out at 3000!!!! help (WCI)
solved that problem. hx ecu. Now it cuts at wot. Any ideas, It is throwing map and iacv.
Old Sep 16, 2003 | 10:03 PM
junya16's Avatar
i had the same problem a while back and it was the map sensor...u throwin any codes???
Old Sep 16, 2003 | 10:26 PM
WCI's Avatar
WCI
Default Re: 91 si conversion dx cuts out at 3000!!!! help (junya16)
yea Im throwing map. think its just bad or could it be that I hooked up the vacuum lines wrong?
ELeMeNTs153
14
May 24, 2013 01:35 PM
d16X
Aug 14, 2004 10:44 AM
white99gsr
Apr 1, 2003 04:37 AM
RuffRhyno
Aug 29, 2002 07:00 PM
MisterB
Feb 23, 2002 11:11 PM
