Slight rattle sound
When I don't have my car in gear and I press down the accelerator slightly, I hear this little rattling sound coming from about the center of the car. I'm guessing it's my heat shield starting to come off and it's rattling. What you guys think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic »</TD></TR><TR><TD CLASS="quote">Probably heatshield. Take it off. No harm done. </TD></TR></TABLE>
Just wondering how can you tell if it is the heatshield or the A-pipe that's rattles?
You'd kind of have to hear it, I guess. Heatshield is usually somewhere between 3-4K RPM as well. I don't know, really. I just go with heatshield as a first guess since that's almost always what it is. If the problem isn't solved, start looking into other things.
Yep my car also does a strange rattle type sound when I let go of the accelerator it does that sound at about 3.5k I guess it is the heat shield.
How would I go about in removing the heat shield?
my car does the same **** with dc header ( no heat shield). thought it was my cat, so i disconnected it (open header) and still makes the ******* nosie..
they tell me it might be my exhaust gasket...
u might wanna check that out...
buzlink
14
Sep 17, 2003 05:39 PM
It should be bolted on there, my guess with some 8 or 10mm bolts...
