Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
93 Legend Brakes
Old Sep 16, 2003 | 05:36 AM
legendman's Avatar
Default 93 Legend Brakes
My brakes would work OK for the most part. But lately the pedal would start to go down and actually got to floor after driving some distance (always at stoplight). I replaced MC (did not bench bleed), put on all new pads, and have bled the @#$# to death. Pedal goes to the floor every time. No leaks anywhere. Power booster makes a hissing sound when pedal is depressed. Apparently, air is going around the MC mounting. Anyone know what is going on?
Modified by legendman at 6:35 PM 9/18/2003
Old Sep 17, 2003 | 12:41 AM
RangerJoe's Avatar
Default Re: 93 Legend Brakes (legendman)
you need to replace the brake master cylinder. this is a very common problem for legends with alot of miles, but once you replace it, you should be good for a long time. i know you said you already did, but this is what happens when you have a dead one. you MAY need to install new brake lines. that also could be the problem. if you have a bulge in a line somewhere, or a hole. you might as well get SS braided cables, which will also help performance.
thats my $0.02
dnl_hcktt
Mar 6, 2008 09:49 AM
Civicracer17
Aug 15, 2006 03:07 PM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
peja43916
38
Dec 25, 2004 10:42 AM
