overheating honda
Old Sep 16, 2003 | 01:42 AM
windg@t's Avatar
Default overheating honda
Hi wonder if someone could help. Have a 1986 SOHC honda 150, head and cam was done, and branches was added, has a weber 36 dcd carb and cold air intake. The problem is, when driving normal the car doesnt overheat, but as soon as you drive full throttle the car tends to overheat, slowing down and the temp comes down. Radiator was recore before the mods, new termostat was added and radiator was flushed. Could it be the timming as we are struggling to get the timming marks to line up after the cam was done, would a adjustable pully help, or are the radiator to small, will it help if we remove the aircon radiator in front of the normal radiator, or if we use termo wrap with the branches. One otherthing on cold days and morings you can drive it at full throttle with out overheating, only when its warm outside it tends to overheat. Need some advice. anyhelp would be appreciated. Head gasket is fine.
Old Sep 16, 2003 | 02:14 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: overheating honda (windg@t)
Sounds like it's running lean to me
Old Sep 16, 2003 | 05:07 AM
T4eg's Avatar
Default Re: overheating honda (92 civic VX B18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it's running lean to me</TD></TR></TABLE>
lean=hot
rich=cool
Old Sep 17, 2003 | 12:59 AM
windg@t's Avatar
Thanks for the info, will be doing the CO check reading this weekend and also check the timing again. Will let you know if it worked.
Thanks
ed lome
Jun 17, 2017 07:17 PM
raider1qaz
Aug 2, 2013 09:07 AM
chrisfromsrq
Oct 14, 2009 11:52 AM
scoobyghost
Mar 28, 2007 05:18 PM
