I have a slight miss in the motor
Old Sep 15, 2003 | 06:50 PM
solman74's Avatar
Default I have a slight miss in the motor
This is for you B16 folks. I just about finished the swap. Only a few more things left to work out. does any one not have the front mount? I only have the driver side, trani and rear hasport mounts. My motor shakes like a leaf. I think it might have something to do with the wires but not sure. Also wanted to ask about the mounts as well.
Old Sep 15, 2003 | 06:53 PM
FULL-RACE EP3's Avatar
Default Re: I have a slight miss in the motor (solman74)
You should not have to worry about the front mount, the three you have should be more than enough. Are the mounts new? If not how are the bushings? Explain what you mean when you are talking about the wires?
Old Sep 15, 2003 | 07:44 PM
solman74's Avatar
Default Re: I have a slight miss in the motor (Pooptooth)
I'm talkinga bout moving the plug wires where it reaches the plug. I'm talking about moving the wire down some. I don't for some reason it's got a rough idle and the motor definatly rocks hard core under accessalation. NOOOOOOO, the mounts are brand new. The motor still rocks. I'm wondering if these wires are pooched.
Old Sep 15, 2003 | 07:46 PM
deepstaged's Avatar
Double check your firing order...
Old Sep 15, 2003 | 09:28 PM
solman74's Avatar
Default Re: I have a slight miss in the motor (deepstaged)
I did off a gsr. They should all be the same. It's correct. Got any idea's on trouble shooting a Code 21??
95JDM
Nov 17, 2007 02:46 PM
yesSiReK
13
Jan 29, 2007 07:07 PM
97turboteg
Apr 21, 2006 11:51 AM
george34
Dec 9, 2005 06:52 PM
civic_driver
Nov 1, 2005 10:22 AM
