help... puttin on rotor/hub onto wheel bearing
Old Sep 15, 2003 | 06:45 PM
ironcheftony's Avatar
Default help... puttin on rotor/hub onto wheel bearing
i need help asap, currently working on it rite now, i just put on a new wheel bearing on my accord, the passenger side, i cant seem to get the rotor/hub assembly in all the way, it goes in half way and stops, has any 1 done this before, how would i get it on all the way ? i wonder if i hammer it in will the wheel bearing mess up , i dunno i need help , tia
Old Sep 15, 2003 | 07:26 PM
Stripped Honda's Avatar
99-0104
Default Re: help... puttin on rotor/hub onto wheel bearing (ironcheftony)
yes you can hammer it not too hard but just enough to get the axle threads started and just use the impact gun to tighten the axle nut and it will push the bearring in
Old Sep 15, 2003 | 07:45 PM
i wasnt talkin about puttin the axle in, thats easie, buit i got the problem solved, i took off the bearing and hammered it onto the hub, hope it dint mess n e thing up
method520
Mar 15, 2010 09:08 AM
rcgrillo
Sep 8, 2008 04:38 PM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
jBj
Apr 17, 2007 12:54 PM
slowteg550
Suspension & Brakes
Jul 21, 2006 07:30 AM
