Brake Problems....
So here's the problem. When the break pedal is applied for a few seconds, the pedal moves farther and farther until it reaches the floor and I hafta put a lot of effort to keep the car in the current position without rolling. Anyone have any ideas as to what is causing this? Thanks...
Car is a 91' CRX Si with b16
One of 2 things come to mind. Either the booster is going bad on you or a vacuum problem with it. Or the dreaded MC failure or bleeding was done wrong problem. Actually, it sounds more like a cylinder issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">Classic symptom of a bad Master Cylinder Main Seal leaking.</TD></TR></TABLE>
may as well swap to a 15/16ths master. better brake feel and higher engagement point
prob, master cylinder, just changed mine with 170,000 miles on it on my 89 CRX Si. Just make sure to get a new one and not a rebuilt one you'll be happy you did in the longrun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">If you get a new one upgrade to an Integra 15/16s one along with Integra Booster.</TD></TR></TABLE>
so far this is the best way. bigger master and definately boosted correctly.
-spenc
-spenc
