What needs done on a D16Y8 swap to a B18C1 swap?
Old Sep 15, 2003 | 02:43 PM
MonsterVtec's Avatar
Default What needs done on a D16Y8 swap to a B18C1 swap?
What needs done on a D16Y8 swap to a B18C1 swap? i blew my d16y8 motor today in my 00 civic ex and now i want to do a swap whats easiest setup basically?
Old Sep 15, 2003 | 05:41 PM
Katman's Avatar
Default Re: What needs done on a D16Y8 swap to a B18C1 swap? (MonsterVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonsterVtec &raquo;</TD></TR><TR><TD CLASS="quote">What needs done on a D16Y8 swap to a B18C1 swap? i blew my d16y8 motor today in my 00 civic ex and now i want to do a swap whats easiest setup basically?</TD></TR></TABLE>
the easiest setup is getting another Y8 long block and replacing your blown one. Seriously, it is. If you go b-series you'll have to get motor mounts, shift linkage, axles, etc...the whole works...and pay about $3000+ for a B18C1 engine; when you can just buy a Y8 engine from someone (a friend perhaps) who did already has done a B-series swap, for way cheaper. Its up to you though. I'm just answering your question from a 'easiest setup' stand point as you stated in your question.
but...
If you do wanna go B-series, any B-series engine will install just the same. Just make sure you buy an OBD2/96+ B18C swap if want the swap to go someone easier (the electronics are compatible with your 00 EX).
Old Sep 15, 2003 | 05:56 PM
Default Re: What needs done on a D16Y8 swap to a B18C1 swap? (Katman)
ttt
gnxpro24
Northeast (Sales)
Aug 27, 2014 05:43 PM
byc_cb7
26
Aug 7, 2009 06:50 AM
Project_EK
Oct 9, 2005 02:55 PM
ricetoniceeg
20
Apr 16, 2005 02:23 PM
