b18c5 block and Gsr head?
From: Your really lame if you dock my points, WA, 98033
c-speed says the compression will be about 11:1 how much hp will this put out with just minimal boltons? like intake header exaust and skunk2 IM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruthlessbucket »</TD></TR><TR><TD CLASS="quote">you think 185-190 whp is possible with stock b18c5 block and stock gsr head with skunk2 IM and boltons.?</TD></TR></TABLE>
im sure which ecu u run would play a big part... what IM u ganna use?
Maybe, with some really good tuning and header. If you can dump the GSR cams, and at least get some CTR or ITR cams. That might get you closer to your goal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr »</TD></TR><TR><TD CLASS="quote">
kenji p28 probably and a vafc.
im probably gonna use my dc 4-2-1 1 piece header im kinda on a budget and i found a good price on this block. so im hoping to trade off parts from my ls/vtec for this swap.
kenji p28 probably and a vafc. </TD></TR></TABLE>
u might wanna dump the gsr IM cuz u wont be using the secondaries
okay so what would be better in my sitiuation, Using a Gsr head or B16 head. i dont plan on doing any internal work on the b18c5 just yet.
i have a b16 head already but its been tapped for ls.vtec already and im not sure if i want to use it or not. so i was thinking of just trading it away for a gsr head.
many will argue that a b16 head is better cuz it flows better since it has a perfectly round combustion chamber and better IM, but the fact of the matter is, its not that much better unless your motor is fully built and running in the pros. i think on a semi-stock motor, a gsr head would be better because of the higher CR. compression make a world of a difference
the dyno charts even show only a few HP difference. plus the gsr head looks like its doin better
http://www.alaniztechnologies.....html
its a 88-91 b16a head its been around for a while. i could always use it ofcourse but i could also just trade away for something newer.
also if i did use the b16 head, could i just reverse all the stuff i did to make it work on my ls/vtec like resize the dowel holes and block the oil passage?
also if i did use the b16 head, could i just reverse all the stuff i did to make it work on my ls/vtec like resize the dowel holes and block the oil passage?</TD></TR></TABLE>
yes u can
yes u can
hey i'm putting together a smilar setup. Mines is:
b18c5 block
2k1 gsr PnP head w/ port match to skunk2 mani
itr cams
aem camgears
99 jdm itr Ecu
aem cai, greddy 4-2-1 header, stock cat, greddy exhaust and i'm debating on a 50shot
b18c5 block
itr cams
aem camgears
99 jdm itr Ecu
A little research on the poster DocV would have enlightened you to a few critical details:
1) His car was stolen.
2) He hasn't posted since June of 2007.
3) His signature states that he is DONE with Hondas.
Forget this poster and search some more... this combination has been done THOUSANDS of times and there is plenty of data on it.
swaytec360
Jul 18, 2007 10:10 AM
jdmjeff
Southeast (Sales)
17
Mar 16, 2006 03:31 PM
