4th gen and 5th gen h22 exhaust maniold/header the same??
do anyone know if the h22 on 4th gen and 5th gen are the same?? i kno the length of the downpipe are different, but does all the bolt holes match????
Nope. I am sure you could make it work. For the most part I beleive they are different. Where the cat mounts and where the down pipe mounts to the rear bottom side of the block, that mounting plate is a bit longer on the 5th gen than on the 4th gen.
I ran into these questions myself when my swap was done. What it that you are doing?
Are you putting a H22a4 into a 4th gen? If it has everything Header & Downpipe, I would think all you have to worry about is if it lines up @ the cat> I don't think they do.??????> I could be wrong.
yes, but Cat locations and ill the hangers still line up....Im looking at getting the GReddy 4-2-1 and it says i is only for the 92-96 Vtec, I know same engine and same type chassis (BB), but my question...actually 2 is will everything line up with no modification, and didnt GReddy make a 4-1 stainless header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz »</TD></TR><TR><TD CLASS="quote">yes, but Cat locations and ill the hangers still line up....Im looking at getting the GReddy 4-2-1 and it says i is only for the 92-96 Vtec, I know same engine and same type chassis (BB), but my question...actually 2 is will everything line up with no modification, and didnt GReddy make a 4-1 stainless header?</TD></TR></TABLE>
The original poster acknowledged the difference in lengths...
4th gen header is about 6 inches longer than a 5th gen base, maybe 2 inches longer than an SH header. Greddy only makes a 4-2-1
ophdehEEzY
Mar 22, 2003 02:16 PM
