KYB shocks from an EG fit an EF?
Old Sep 15, 2003 | 05:54 AM
iceboy's Avatar
Default KYB shocks from an EG fit an EF?
have the opportunity to purchase some KYB Gear Climb shocks off an EG civic.
two questions:
1) can anyone provide me with some info on these please, as I can't find any on KYB website.
2) are EG shocks any different to EF shocks? i.e will these fit onto an EF9 (a real one)
Old Sep 15, 2003 | 07:53 AM
Eggman's Avatar
Default Re: KYB shocks from an EG fit an EF? (ICEBOY)
to fit the front struts on you'll need the EG/DC style front forks. and the rears should just bolt in. BUT stock versus stock, the EG struts are longer than the EF ones. so you will lose travel. don't know the comparison from kyb gc EG struts compared to stock EF ones, though. you might gain travel, lose travel, or stay the same.
here's a exert from kybclub.com, translated by babelfish.altavista.com,
http://babelfish.altavista.com/babel...2FType-bc.html
hope that helps. now hook me up with some new zealand EF9 side moldings.
Old Sep 15, 2003 | 08:16 AM
Doctor CorteZ's Avatar
rear shocks will need a spacer , the shock fork is slightly thinner on the EF.
Old Sep 15, 2003 | 08:18 AM
Eggman's Avatar
Default Re: KYB shocks from an EG fit an EF? (Doctor CorteZ)
i thought in new zealand, they had real ef's...meaning 88/itr/jdm style LCAs and rear struts.
Old Sep 15, 2003 | 08:34 AM
Default Re: KYB shocks from an EG fit an EF? (Eggman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman &raquo;</TD></TR><TR><TD CLASS="quote">i thought in new zealand, they had real ef's...meaning 88/itr/jdm style LCAs and rear struts.</TD></TR></TABLE>
aw **** , you're totally right...
Old Sep 15, 2003 | 08:56 AM
Lo-Buck EF's Avatar
thats iffy. i have eg coilovers on my ef and the rears fit no problem
Old Sep 15, 2003 | 08:58 AM
Default Re: KYB shocks from an EG fit an EF? (Lo-Buck EF)
OEM struts from a 91 wouldnt fit on my 92 , they were too thin on the shock fork...
hmmm.....
Old Sep 15, 2003 | 09:13 AM
Lo-Buck EF's Avatar
fronts? yes. to use eg sus in ef or ef sus in eg, u need to use the shock forks that shock year.
the rears *should* be the same......
-spenc
Old Sep 15, 2003 | 09:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">fronts?</TD></TR></TABLE>
I've said rear from the start , I know you need EG front forks...
Old Sep 15, 2003 | 09:42 AM
Lo-Buck EF's Avatar
ok. just clarifying. i guess the oe stuff had a differant clerance on the rear fork than aftermarket stuff.
Coolero
Feb 14, 2010 07:42 PM
724chris
Jan 10, 2010 06:40 PM
724chris
Dec 16, 2009 10:47 PM
t57b18
Oct 2, 2006 07:31 PM
UK_EG
Suspension & Brakes
Oct 4, 2005 03:05 PM
