Question on lowering the R~!!! Guru knowledge needed
Old Sep 14, 2003 | 10:38 PM
Kicker773's Avatar
Default Question on lowering the R~!!! Guru knowledge needed
ok, thinking of getting spoon springs to lower the itr, but would it rub if i had stock suspension and tires are 205/50/15?
Old Sep 14, 2003 | 10:42 PM
B2FiNiTY's Avatar
Default Re: Question on lowering the R~!!! Guru knowledge needed (Kicker773)
You will be fine.
Old Sep 14, 2003 | 11:50 PM
Kicker773's Avatar
Default Re: Question on lowering the R~!!! Guru knowledge needed (B2FiNiTY)
dope now i need to get dem springys
Old Sep 15, 2003 | 12:38 AM
00 FBP ItR's Avatar
why do people like spoon springs? aren't they progressively wound?
I would rather go w/ som race springs (neuspeed/H&R)
Old Sep 15, 2003 | 03:41 AM
jond's Avatar
Default Re: Question on lowering the R~!!! Guru knowledge needed (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">why do people like spoon springs? aren't they progressively wound? I would rather go w/ som race springs (neuspeed/H&R) </TD></TR></TABLE>
They are. I wouldn't put progressives on anything I drive.
Old Sep 15, 2003 | 04:31 AM
Pompiuses's Avatar
Default Re: Question on lowering the R~!!! Guru knowledge needed (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
Why?
Old Sep 15, 2003 | 05:31 AM
jond's Avatar
Default Re: Question on lowering the R~!!! Guru knowledge needed (Pompiuses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Why?</TD></TR></TABLE>
Just seems like you're sacrificing a little bit of handling for comfort. I dont want any lean when I turn.
I'm probably wrong though.
Old Sep 15, 2003 | 06:48 AM
Pompiuses's Avatar
I don't like my H&R progressive springs when driving "off throttle" through chicanes when tracking. Then the car won't set and you get too much body roll. When cornering at full throttle the springs are nice and stiff though. The little bit of extra comfort is also nice, specially when driving in the city.
Old Sep 15, 2003 | 07:03 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">They are. I wouldn't put progressives on anything I drive.
The stock rear rate is progressive. Comfort is not the main concern why Honda did that. The main reason was that when passing a small bump, the rear won't "bounce" and cause the rear tires to loose contact with the ground unexpectedly.
Old Sep 15, 2003 | 07:16 AM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">ok, thinking of getting spoon springs to lower the itr, but would it rub if i had stock suspension and tires are 205/50/15? </TD></TR></TABLE>
You'll be find for about 15-20k miles. Then, your shocks will die and you'll have a nasty ride.
Vtec-IsMyAntiDrug
Oct 14, 2004 08:13 PM
mcdt
Acura TSX
Feb 4, 2004 09:37 AM
Euro98ITR
May 14, 2003 09:10 AM
TypeR1558
Jun 2, 2002 09:10 AM
uNF$@#!
Apr 22, 2002 09:58 PM
