mainshaft bearing or input shaft bearing?
Old Sep 14, 2003 | 10:28 PM
BI8B's Avatar
Default mainshaft bearing or input shaft bearing?
what are the difference? what are the symtoms of them going bad?
Old Sep 15, 2003 | 05:47 AM
Dan GSR's Avatar
Default Re: mainshaft bearing or input shaft bearing? (BI8B)
you can feel fore/aft play in the input shaft
you have replaced your throw out bearing....but still hear a noise.....but when you press the clutch pedal it goes away
Old Sep 15, 2003 | 10:49 AM
BI8B's Avatar
Default Re: mainshaft bearing or input shaft bearing? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">you can feel fore/aft play in the input shaft
you have replaced your throw out bearing....but still hear a noise.....but when you press the clutch pedal it goes away</TD></TR></TABLE>
huh?
Old Sep 15, 2003 | 10:53 AM
quik1's Avatar
Main shaft bearing noise can be heard with the clutch out but when you press on the clutch the noise goes away.
Old Sep 15, 2003 | 10:54 AM
mmuller's Avatar
Mad Scientist
they make noise...easy
What dan gsr ment is that when your input shaft bearing goes bad, it kinda sounds like when your release bearing goes bad...
when you press on the clutch is goes away..
Old Sep 15, 2003 | 11:17 AM
BI8B's Avatar
Default Re: mainshaft bearing or input shaft bearing? (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">Main shaft bearing noise can be heard with the clutch out but when you press on the clutch the noise goes away. </TD></TR></TABLE>
people have been telling me that if the clutch is out and there's a grinding/knocking sound then it's the input shaft bearing. but if you step on the clutch pedal, it goes away. so is it the mainshaft or the input bearing?
Old Sep 15, 2003 | 11:25 AM
mmuller's Avatar
Mad Scientist
could be theinput shaft bearing or if it sounds kinda like a helicopter it could be your release bearing
Old Sep 15, 2003 | 11:40 AM
BI8B's Avatar
Default Re: mainshaft bearing or input shaft bearing? (mmuller)
how would i know what to replace? should i just replace them all since i'm already going to open the tranny?
Old Sep 15, 2003 | 01:43 PM
PupaScoopa's Avatar
You might as well since they're cake to replace on the input shaft. You'll also need to re-shim the shaft.
Old Sep 15, 2003 | 02:43 PM
quik1's Avatar
Default Re: mainshaft bearing or input shaft bearing? (PupaScoopa)
Its one of them either way so pop it open and check them out. I would probabally just change them both.
Old Sep 15, 2003 | 04:32 PM
BI8B's Avatar
what does re-shim mean?
Old Sep 16, 2003 | 06:14 AM
Dan GSR's Avatar
well you need a helms manual
i hope your not trying this without one
and second.....the input shaft is another name for the main shaft
the other shaft in you tranny is the counter shaft.....
you obviously don't know what your getting into......
craigaria
23
Nov 24, 2012 02:18 PM
hcs1jimmy
Apr 19, 2011 04:12 PM
ksJoe
19
Dec 30, 2008 07:21 PM
Ek9Max
Mar 15, 2005 07:19 PM
