Autometer Air/Fuel Gauge now working after Hondata install
Old Sep 14, 2003 | 10:23 PM
nadc2's Avatar
Default Autometer Air/Fuel Gauge not working after Hondata install
Does anyone know why my Air/Fuel Gauge stays pegged at rich after I installed my hondata s100? It was working fine with the stock ecu, but now after changing over to obd1 and putting in the hondata s100 the gauge just stays at rich all the time. I've heard stories that the A/F guage doesnt work with chipped ecu's but is there any reason behind this???
Old Sep 15, 2003 | 06:51 AM
ltho1998's Avatar
Default Re: Autometer Air/Fuel Gauge not working after Hondata install (nadc2)
Sounds like you have a wire loose. If the meter doesn't receive an input for O2 it pegs rich.
And i have a chipped ECU and it works fine so.. it should work.
Old Sep 15, 2003 | 07:02 AM
PM-Performance's Avatar
Default Re: Autometer Air/Fuel Gauge not working after Hondata install (ltho1998)
Did you wire it to the sceondary 02? if so thats prob why
Old Sep 15, 2003 | 07:41 AM
Rory Breaker's Avatar
Yep, sounds like either a nonexistent or loose connection to the 02 to me.
Old Sep 15, 2003 | 11:30 AM
nadc2's Avatar
Default Re: Autometer Air/Fuel Gauge not working after Hondata install (newgsrdriver)
I wired the purple wire to the solid white wire on the ecu harness. I have an obd 2 harness with a hondata p28 ecu made to fit an obd2 harness if that makes any difference at all. I checked again and all of the connections are secure. Any other suggestions you guys have?
Old Sep 15, 2003 | 05:35 PM
nadc2's Avatar
ttt
Old Sep 17, 2003 | 12:07 AM
ECKOTYPER's Avatar
U CAN HOOK IT UP TO THE O2 SEONSOR, OR STRAIGHT TO THE ECU, SO IF U HAVE IT HOOKED TO O2 TRY JUMPING IT OVER STRAIGHT TO THE ECU HARNESS AND IT SHOULD FIX THE PROBLEM
Old Sep 17, 2003 | 12:08 AM
nadc2's Avatar
Default Re: Autometer Air/Fuel Gauge not working after Hondata install (ECKOTYPER)
it is hooked up to the solid wire on the ecu harness
Old Sep 17, 2003 | 01:21 AM
Dee's Avatar
Dee
Please do NOT use that AF meter for tuning! It's nothing more than an idiot light since it uses the stock narrow band sensor. Oh yeah, you have a bad connection.
Old Sep 17, 2003 | 10:00 AM
Spunkster's Avatar
If this has been tuned, check with your tuner to see if they burned the chip in open or closed loop. If it was set in open loop, then the A/F guage will not be worth the plastics it's made of. If this is a base ma, it doesnt' really matter, just go get it tuned.
bigtom388
Engine Management and Tuning
Jul 28, 2011 09:45 AM
StrtRacerB16A2
Aug 27, 2006 10:50 AM
99TurboFerio
Apr 17, 2005 11:45 AM
3 plus 1
Apr 7, 2004 05:52 PM
Ignitecivic
Apr 20, 2002 04:45 PM
