Wierd Noise when i turn on my GSR
Old Sep 14, 2003 | 06:48 PM
MyLittleRedCar's Avatar
Default Wierd Noise when i turn on my GSR
Whenever i turn on my GSR, and the engine is cold, (sometimes with the engine a little hotter), i hear this like... clacking noise... for a few seconds (3-8 seconds) and then it starts idling normally... don't know how long its been happening but whatever, does anyone know what might be the cause of this????? is it normal>????
Old Sep 14, 2003 | 07:01 PM
iH8RICERZ's Avatar
Default Re: Wierd Noise when i turn on my GSR (MyLittleRedCar)
what type of clacking noise? are you referring to the abs pump?
Old Sep 14, 2003 | 07:30 PM
mr.beeks's Avatar
Default Re: Wierd Noise when i turn on my GSR (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">what type of clacking noise? are you referring to the abs pump? </TD></TR></TABLE>
yeap it sound like the abs pump
usually it sound like a washere machine
so have a tech take a look at it
Old Sep 14, 2003 | 11:28 PM
well ok... my ABS light, SRS light have been on now for about 2 or 3 months.. and i hope its not an engine thing, i did valve adjustment last month and do my oil change religiously... so i don't know... it sounds like metal hitting something... but i don't know... i'll fix my ABS and see if it goes away...
btw, how much should i be paying for a speed sensor (the problem with my abs) at a junk or at honda???
Old Sep 15, 2003 | 06:46 AM
ltho1998's Avatar
Default Re: (MyLittleRedCar)
My ABS pump sounded like valves clacking when it went out. So just pull the ABS fuses and see if it still happens.
Db1 Supreme
Oct 26, 2005 03:02 PM
1992gsrb17
Mar 24, 2004 03:00 PM
1992gsrb17
Mar 23, 2004 12:21 PM
social_control
Sep 18, 2003 01:54 PM
Mr. Softee
Sep 10, 2001 05:56 PM
