crx swap info
Old Sep 14, 2003 | 04:13 PM
redds's Avatar
Default crx swap info
im trying to figure out what is exactly needed for a d16z6 swap in a 91 crx dx. i have various crx SI parts. i have searched for weeks now and keep comming up with bits and peices but i want to be sure. i know it has to be converted to OBD 1. heres the thing, i have a harness intake, trans and injectors form a 90 crx si. so my question is can i just plug the engine harness from the SI in place of the dual point harness or is it more involved? does the d16z6 computer have to be used or can i use the SI comp with a VAFC to activate vtec? i also plan on boosting the motor too.
one more thing.. i thought of a b16 swap but it seemed like a lot of work. would this be as easy or should i go d series. id like DOHC though. any help you guys could give would be great.
thanks
redds
Old Sep 15, 2003 | 11:57 AM
HOnDA CRiX's Avatar
im doing the same thing with crz right now 1.5 to z6 all i needed was msd rpm activater switch to switch the vtec on im using the dx trans for right now and thats about it my uncle is going to wire it up and then im good but im having a problems with pulling the drive shafts out the control arm is frozen and im pissed i really don't know that much about cars and **** but good luck
tOuGe#1
Aug 24, 2014 12:55 PM
freddy chavez
Dec 25, 2012 12:28 PM
maxxdout
Oct 11, 2005 06:25 AM
redds
Sep 21, 2003 06:45 AM
