ATTN. people with dohc ZCs in 88 crx HFs
Old Sep 14, 2003 | 02:35 PM
akb16's Avatar
Default ATTN. people with dohc ZCs in 88 crx HFs
what axles did you guys use? im having a little trouble finding out which ones fit....thanx
Old Sep 15, 2003 | 02:46 PM
akb16's Avatar
Default Re: ATTN. people with dohc ZCs in 88 crx HFs (akb16)
little help guys
Old Sep 15, 2003 | 03:27 PM
jester's Avatar
from my understanding the older 89 teg axles are supposed to work... but im not sure
Old Sep 15, 2003 | 03:31 PM
DohcVtecCrx's Avatar
what tranny are you using? You should be using your hf axles
Old Sep 15, 2003 | 03:41 PM
SOHCrx's Avatar
Default Re: ATTN. people with dohc ZCs in 88 crx HFs (DohcVtecCrx)
which Tranny and Knuckle assymblies are you using? with that info i can be of help... lemmie knoe
Old Sep 15, 2003 | 04:50 PM
Doc_Honda's Avatar
Default Re: ATTN. people with dohc ZCs in 88 crx HFs (SOHCrx)
I think hes using the ZC tranny as well... isnt this gonna require the axles from the Si in this case?
Old Sep 15, 2003 | 05:12 PM
FourthGenHatch's Avatar
HF and STDs had knuckles with 23 splines. The ZC Tranny I'm 99% sure requires the use of the Intermediate Shaft (since the imput holes are larger than the other 88-91 trannies) so that means you need 89 Integra axles. However their outer splines are 26. So if you have an HF you need to upgrade to DX or Si knuckles with 26 splines so you can use the proper tranny.
If you are using any other tranny than HF axles should work fine.
Old Sep 15, 2003 | 05:19 PM
akb16's Avatar
Default Re: ATTN. people with dohc ZCs in 88 crx HFs (FourthGenHatch)
im using dx knuckles......the problem is i cant find any axle combo that can line up the Intermediate Shaft holes with the hf body holes...so i cant bolt down the intermidiate shaft....ive tried 86-87 integ, 88-89 integ, and 90-93 integ....should i try Si axles maybe?---thanx
Using the ZC tranny
Old Sep 15, 2003 | 05:22 PM
The Intermediate Shaft bolts to the back of the engine block, not to the body of the car.
Old Sep 15, 2003 | 05:28 PM
akb16's Avatar
yea dont know what i was thinkin up there.....anyways they dont match up to the zc block
Old Sep 15, 2003 | 05:44 PM
The ZC realistically needs the ZC intermediate shaft. However I heard the 89 Intermediate shaft will work if you cut the top of it's bracket off.
Old Sep 15, 2003 | 06:00 PM
akb16's Avatar
Default Re: (FourthGenHatch)
hmmm......maybe i'll check that out, since im probly not gonna find a zc intermediate shaft
Old Sep 15, 2003 | 11:56 PM
SOHCrx's Avatar
Default Re: (akb16)
i'd say find a zc intermediate shaft, and if you do 90-91 integra axles should work with it (thats my brothers set-up with his DOHC zc, zc tranny w/intermediate shaft, 90-91 teg axles). i actually think my bro has a spare intermediate shaft so i'll ask him and let you knoe. if all else fails jus get an Si tranny and run ur Si axles and ur set! thats wut im doin on my single cam ZC. hope u've been helped and good luck.
Old Sep 16, 2003 | 06:36 AM
slooogsr's Avatar
if u found a 88-89 si trans in the first place you could have used the hf/knuckles/ and axles as i did with my 90 swap........
trav_89_crx_b7
Aug 22, 2011 05:14 PM
na91hatch
Jan 14, 2006 06:59 PM
sabertooth
Sep 4, 2003 06:13 AM
pdiddyparsons
Mar 18, 2003 05:59 PM
NipponRacing
Mar 23, 2002 04:22 PM
