can anyone help me with mpfi swap right now?
Old Sep 14, 2003 | 02:17 PM
HatchBox's Avatar
Skoobie no more...
Default can anyone help me with mpfi swap right now?
im me Ind3ciso
Old Sep 14, 2003 | 02:28 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: can anyone help me with mpfi swap right now? (ind3ciso)
*link*
*link2
*link3
*link4
*link5
Old Sep 14, 2003 | 04:31 PM
HatchBox's Avatar
Skoobie no more...
i just cant get the wire out from the b2 spot on the clip that goes to the ecu i have to move it to b10...but it wont comout...suggestions??
and the god damn si distrubuter wires dont match up (color wise) to the ones in the diagrams!
Old Sep 14, 2003 | 05:24 PM
HatchBox's Avatar
Skoobie no more...
someone please help
Modified by ind3ciso at 9:37 PM 9/14/2003
Old Sep 14, 2003 | 05:47 PM
plonger's Avatar
I took out mine with a sewing needle. Its hard to explain but i insert the needle in front of the plug and i hit it with a small hammer .. it worked great for me
Old Sep 14, 2003 | 05:57 PM
civickiller's Avatar
Default Re: can anyone help me with mpfi swap right now? (plonger)
did u take out the small little plastic thing on the top or bottom of the harness so u can get it out ?
Old Sep 14, 2003 | 05:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: can anyone help me with mpfi swap right now? (civickiller)
yup
Old Sep 14, 2003 | 06:02 PM
plonger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">did u take out the small little plastic thing on the top or bottom of the harness so u can get it out ?</TD></TR></TABLE> yeah its pretty important to remove them
Old Sep 14, 2003 | 06:05 PM
HatchBox's Avatar
Skoobie no more...
hahaha yeah...this problem isnt as big as my Distrubuter problem ...i can always cut the wire and buy a new clip...
Old Sep 14, 2003 | 09:50 PM
solman74's Avatar
Don't do that. Just repin it. I mean it should be fine. You only have to run 2 extra wires for TDC. I just finished a B16A swap. It runs fines. No codes. We had 2 in the begining but after swaping the sensors (IAT, AECV) around very thing was fine. Nice work if I do say so. Now I just have to find a nice plug to wiring up the extra wires ran. I'm done. We Oh back to the Dizzy. My friend wrote done the stock B16 wire batter. He unpinned the connector. Then transferred as man as he could from the stock Dx harness and then all I had to do was run the two extra wires from the ecu directly to the Dizzy which I believe was C1 and C2.
Old Sep 15, 2003 | 06:21 AM
HatchBox's Avatar
Skoobie no more...
Default Re: can anyone help me with mpfi swap right now? (solman74)
on the back of my throtle body by the top right there is a small plug and it has 2 wires coming out of it...a black and yellow and a blue wire...where do these wires go?
Old Sep 15, 2003 | 01:42 PM
HatchBox's Avatar
Skoobie no more...
help
Old Sep 15, 2003 | 04:48 PM
HatchBox's Avatar
Skoobie no more...
and now i need help where does the clear plug go to...its one of the 3 clips i have to remove there is two wires a orange and a black and yellow
Old Sep 15, 2003 | 07:43 PM
HatchBox's Avatar
Skoobie no more...
which one do i use....the integra one or the civic one...if i disconnect the civic one there will be a open hose...
wtf is this for...has two wires coming out of it...grrrr
Old Sep 16, 2003 | 04:11 AM
HatchBox's Avatar
Skoobie no more...
someone...
Old Sep 16, 2003 | 05:43 AM
FourthGenHatch's Avatar
Go to http://www.fourthgenhatch.com and go to the How-To section. Look under the engine swap part and read the ZC and MPFI articles. It has pictures of all the plugs, where they go, and the wire color. Will be the same for going Si.
Old Sep 16, 2003 | 08:45 AM
paybac4223's Avatar
Default Re: can anyone help me with mpfi swap right now? (FourthGenHatch)
ok here are all the links you will need for your problems...
to remove the pins @ the ecu just go to the 99 cent store and grab a set of the eyeglass screwdrivers the small flat head ones.... here is how to repin the harness... http://www.deepstaged.net go to the wiring section....you can pm me for pics on how to wire the dizzy...
Old Sep 16, 2003 | 06:27 PM
88DXCRX's Avatar
Click here if pic does not show: http://mediaservice.photoislan...7.jpg
That was the fast idle solenoid on 90-91 models..
On an '88 that is plugged and the solenoid is on the firewall.
If you don't have the wiring for it don't worry about it..
Old Sep 16, 2003 | 06:29 PM
HatchBox's Avatar
Skoobie no more...
Default Re: can anyone help me with mpfi swap right now? (paybac4223)
car start i dont know where this one line goes... here is a Full size pic.... HELP!!!
http://www.imagestation.com/pi...g.jpg
Old Sep 16, 2003 | 06:34 PM
88DXCRX's Avatar
that goes to the Si type intake tube
or try here: http://mediaservice.photoislan...8.jpg
Old Sep 16, 2003 | 06:44 PM
88DXCRX's Avatar
Default Re: can anyone help me with mpfi swap right now? (88DXCRX)
this page shows the plumbing for the small hose,that is a coolant line that flows through the throttle body to the EACV.
http://www.binghamtonlife.com/...3.jpg
Old Sep 16, 2003 | 06:56 PM
HatchBox's Avatar
Skoobie no more...
so that line goes to the valve cover??
Old Sep 19, 2003 | 06:12 AM
HatchBox's Avatar
Skoobie no more...
ok everything is back together but still nothing! it doenst throw any codes at all...Does the SI ecu say AK or MK ? grrrr and i cut 4 wired at the ecu...2 of them i plug back in on the harness side...what about the other 2 do i leave them...
if your looking at the engine bay (from the front) is this the order the injecters go?
I 1 I___ I 2 I ____ I 3 I ____ I 4 I
_________________
Modified by ind3ciso at 10:45 AM 9/19/2003
Old Sep 19, 2003 | 07:23 AM
88DXCRX's Avatar
Number one is on the drivers side;Number four is on the passenger side...
