****Attention DA Owners****
Does anyone know which fuse is for the fuel pump.. cuz I need to find it so I can install my fuel pressure gauge without dumping gas everywhere.. I searched and didn't find much of anything. Any help would be appreciated.
Umm,.....maybe I dont know ****...but cant you just disconnect the battery to install the FPR???? Or jut not turn the key??? THe fuel pump wont turn on unless the key is in.
The fuse should be under the dash as usual.
True, the fuel pump won't turn on, but there's still pressure in the lines. I wanted to start the car with the pump off, so I can get rid of all the fuel in the lines.
As for the fuse, I know it's under the dash, but my fuse door was missing when I bought the car so I don't know which fuse is for what. Maybe you could help me out with that..
Ah...makes more sense.
Starting to sound like a good idea
I dont have your fuse diag tho...so I cant help out.
If you unhook the fuel lines, you wont get too much spray tho....so I wouldnt worry too much about it.
Don't attempt to start the car with no fuel pump running.
Just take the fuel cap off to relieve pressure and make sure you loosen the banjo bolt slowly, put a rag around it to stop any spray.
5fingadiscount
Mar 27, 2008 04:25 PM
