car will not start... getting spark and fuel.
Old Sep 14, 2003 | 01:40 PM
baonest1's Avatar
Default car will not start... getting spark and fuel.
ok, well i have a OBD1 GSR body that had an LS motor in it.. the motor blew, so we put a obd2 LS motor with harness in there. everything is hooked up. we have spark, cuz i tested the wires, and we have fuel cuz i popped an injector out, and fuel came out.
anyone have any ideas what the prob could be. am i going to have to put the obd1 harness back on?? it turns over and over but doesnt want to start. i also swapped the internals of the dist.
thanx
Old Sep 14, 2003 | 01:49 PM
Jet Black's Avatar
Default Re: car will not start... getting spark and fuel. (baonest)
Wondering if the injectors are firing properly?
My advice to you would be to check your wiring order over. Not much else :s
How is the spark timing? Are the wires in the right order?
Old Sep 14, 2003 | 02:16 PM
baonest1's Avatar
Default Re: car will not start... getting spark and fuel. (Jet Black)
yah, plug wires are in right order..
are you talking about the inector wires being in right order.. never knew they could be out of order, but i will check on it.
Old Sep 14, 2003 | 02:19 PM
Jet Black's Avatar
Dont know if they can...just suggesting the logical progression in my mind.
Dont think you can **** em up.....but maybe you missed the fuel injector wires when youd di the swap, or maybe you missed the FI ground...I know I forgot it once and only 2 of the 4 were firing...made for a horrible idle.
Old Sep 14, 2003 | 02:22 PM
baonest1's Avatar
ill double check...
Old Sep 14, 2003 | 04:33 PM
xteg95's Avatar
definately check grounds and make sure your car is timed properly.
Old Sep 14, 2003 | 04:42 PM
gsxr's Avatar
Default Re: car will not start... getting spark and fuel. (xteg01)
how did you match up the wires? color to color? when we did a ZC swap a few of the wires that had the same color were for different use...we had the cam position and the crank postion wires mixed matched...
Jeremiah Thomas
Oct 13, 2018 06:29 PM
OrangeTeggy
Apr 20, 2015 07:33 AM
dumpeDc2
Dec 30, 2004 09:25 PM
Master23
Aug 1, 2004 08:16 PM
DOHCarp
Apr 20, 2003 09:38 PM
