Stock exhaust on itr ok with turbo?
Old Aug 21, 2001 | 01:08 PM
joe pagolac's Avatar
New User
Default Stock exhaust on itr ok with turbo?
How much horsepower would i gain if i add an aftermarket exhaust with a turbo?
Old Aug 21, 2001 | 01:13 PM
Back in Black's Avatar
Rather OG
Default Re: Stock exhaust on itr ok with turbo? (joe pagolac)
You need more flow with FI than the stock setup can provide...
Old Aug 21, 2001 | 01:21 PM
Batoutahell's Avatar
If you boost at 6psi or less, the stock exhaust is ok, but 2.5" is better. If you boost higher than 6psi, you really need a 3" exhaust.
Old Aug 21, 2001 | 01:39 PM
Type Goch's Avatar
New User
Default Re: Stock exhaust on itr ok with turbo? (Batoutahell)
how about 3 inches all the way through with stock muffler?
Old Aug 21, 2001 | 01:49 PM
SpoonCivic's Avatar
New User
Default Re: Stock exhaust on itr ok with turbo? (Type Goch)
That works. Alls u want changed is the piping. Im going to a 3" straight pipe from the exhaust manifold right to the muffler..i heard it gains like 15-20whp.
Old Aug 21, 2001 | 02:42 PM
hybrid_eg's Avatar
Default Re: Stock exhaust on itr ok with turbo? (SpoonCivic)
i think i just might end up going turbo myself.. but not soon.. maybe around new years or something.. if everything goes according to plans.. i should be getting a complete greddy kit for free w/gauges, a turbo timer
I dont plan on boosting more then 6lbs anyhow so i just have to get exhaust, and clutch and that should wrap it up.. i'm still unsure abou ecu management.. i'd like to get power fc since it plugs right up but might settle for hondata... i hope i get this paid for too.. i'll let you guys know in a few months or so
Old Aug 21, 2001 | 05:26 PM
TurboIntegra's Avatar
Get exhaust and a test pipe!!! You will gain HUGE amounts of power. Here is proof::
This is stock exhaust vs 3" Thermal exhaust on a Turbo Si.
http://www.clubsi.com/dyno_napalm_1.shtml if it didnt work.
Old Aug 21, 2001 | 05:35 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Turbo on ITRs =
Old Aug 21, 2001 | 05:44 PM
SuspectProduct's Avatar
New User
Default Re: Stock exhaust on itr ok with turbo? (TurboIntegra)
You gained over 60hp with just an exhaust change? That seems unreal. I bet you're happy as hell with the Thermal guys.
Boostedld9
Welding / Fabrication
Nov 26, 2008 04:47 AM
bloodydc2
Apr 12, 2006 10:55 AM
Dengar
11
Jun 11, 2003 06:07 AM
ITRyder
Jul 3, 2002 01:24 AM
meanteg
Oct 31, 2001 11:37 PM
