88-89 to 90-91 bumper q
Old Sep 14, 2003 | 02:05 AM
crxmadman's Avatar
Default 88-89 to 90-91 bumper q
i never really got a clear answer for this question...but I'm putting a 90-91 bumper on to my 89 CRX...do i need the 90-91 rebar? What else do I need?
(besides the lights)
thanks!!
Old Sep 14, 2003 | 06:48 AM
crxcess's Avatar
Default Re: 88-89 to 90-91 bumper q (4doormadman)
I know that the bumper supports have different part numbers, but the honda dealer said there wasn't a noticable difference and that they should be interchangable.
Old Sep 14, 2003 | 12:04 PM
crxmadman's Avatar
Default Re: 88-89 to 90-91 bumper q (crxcess)
hmmmmmmm....curious
Old Sep 14, 2003 | 09:09 PM
B16ED4G's Avatar
I put a 91 bumper on my 89 hatch, I didn't have to do anything different really. At the bottom the bolt holes didn't quite line up, all I did was redrill the holes in the new bumper and it was a done deal. Fit perfectly
Old Sep 23, 2003 | 12:21 AM
crxmadman's Avatar
Default Re: 88-89 to 90-91 bumper q (B16ED4G)
does anyone know for sure??
Old Sep 23, 2003 | 09:03 PM
crxmadman's Avatar
ttt
Old Sep 24, 2003 | 06:09 PM
crxmadman's Avatar
bump
Old Sep 24, 2003 | 06:17 PM
USDMMARK's Avatar
see..... you can't always trust one source, ive been told you CANT swap a crx bumper on a hatch, it wont fit, but if you say it does i wanna try it, any one can confirm this
Old Sep 24, 2003 | 06:21 PM
auto-x's Avatar
New User
this is ur lucky day, i just did it this afternoon. installed a 91 bumper on my 88.
1. remove bumper turn signal lights(both sides), loosen 2 bolts each side.
2. remove four screws(2 on each side) on bumper that are attached to fender.
3. pull the front bumper gently with the bumper support, do the same thing with your car and it should bolt right up.
Old Sep 24, 2003 | 06:24 PM
USDMMARK's Avatar
Default Re: 88-89 to 90-91 bumper q (auto-x)
it was a 91 crx bumper? can you post pics of the finished productZ???????
Old Sep 24, 2003 | 11:17 PM
crxmadman's Avatar
so you're saying that it does fit with no mod work??
just take off the old one and slap on the new one?
Old Sep 25, 2003 | 09:02 AM
crxmadman's Avatar
yah, I'd like to see some pix as well
Old Sep 25, 2003 | 12:34 PM
USDMMARK's Avatar
can someone please post up these pics i have been given nowhere close to an awnser, ive searched and searched, does anyone have a 90-91 crx si front bumper on there hatch back?
can someone post pics
ive heard you need the fenders and the bumper
but ive also heared that you only need the bumper and to just screw new holes in it,someone help me and fourdoormadman
thanks
Old Sep 25, 2003 | 07:57 PM
crxmadman's Avatar
Default Re: 88-89 to 90-91 bumper q (Dr.D)
bump!!
Old Sep 25, 2003 | 08:00 PM
redzcstandardhatch's Avatar
something different
i put a 89 hatch bumper on a 91 hatch, it worked fine. i'm sure this probably doesnt answer your question though..........i'll just shut up.
Old Sep 25, 2003 | 08:16 PM
carrcarr's Avatar
Default Re: 88-89 to 90-91 bumper q (redzcstandardhatch)
the **** are you asking?......a hatch bumper on a CR-X? if so you should since the front ends are the same.......if you mean CR-X to CR-X....i have 88-89 fenders with a 90-91 bumper on my hatch so im pretty sure it works
Old Sep 25, 2003 | 10:06 PM
crxmadman's Avatar
Default Re: 88-89 to 90-91 bumper q (carrcarr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carrcarr &raquo;</TD></TR><TR><TD CLASS="quote">the **** are you asking?......a hatch bumper on a CR-X? if so you should since the front ends are the same.......if you mean CR-X to CR-X....i have 88-89 fenders with a 90-91 bumper on my hatch so im pretty sure it works</TD></TR></TABLE>
I'm asking for a CRX to CRX swap
a 90-91 bumper onto a 89 CRX
Old Sep 26, 2003 | 06:22 AM
USDMMARK's Avatar
well were not all on the same page here i assume, i am asking for a crx bumper on a hatch im guessing im just gonna have to switch to crx fenders too, anything else ill need?
Old Sep 26, 2003 | 07:33 AM
crxmadman's Avatar
help a brutha out!
Old Sep 26, 2003 | 07:51 AM
kagegod's Avatar
From what I understand the only noticeable difference in the 88-89 and 90-91 CRX bumpers is the front bumper lights. The wings west RS kit is actually made for the 90-91 CRX but fits the 88-89 provided that you replace the front bumper lights. I don't see any reason why you couldn't swap the 90-91 CRX bumper onto your 88-89. Just change the bumper lights and you're good to go.
Old Sep 26, 2003 | 08:29 AM
USDMMARK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doormadman &raquo;</TD></TR><TR><TD CLASS="quote">help a brutha out!</TD></TR></TABLE>
thanks lol
hope you figured your problem out
Old Sep 26, 2003 | 02:47 PM
crxmadman's Avatar
Default Re: (kagegod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kagegod &raquo;</TD></TR><TR><TD CLASS="quote">From what I understand the only noticeable difference in the 88-89 and 90-91 CRX bumpers is the front bumper lights. The wings west RS kit is actually made for the 90-91 CRX but fits the 88-89 provided that you replace the front bumper lights. I don't see any reason why you couldn't swap the 90-91 CRX bumper onto your 88-89. Just change the bumper lights and you're good to go.</TD></TR></TABLE>
kewl, thnx!! You're right though, thats very logical..
Old Sep 26, 2003 | 09:15 PM
Kwicko's Avatar
Default Re: (4doormadman)
Okay, a little clarification (I didn't read all the replies, so this *MAY* have already been answered). I just stripped a dead '89 Civic Si hatchback, so I've had a good look at a few things (got a '91 CRX DX as well).
Civic Hatchbacks and CRXs *DO NOT* - REPEAT - *DO NOT* share a front end. The only piece that is interchangeable as far as the front end sheetmetal goes is the hood. The bumper on the hatchback uses a separate metal "valance panel" above the bumper cover, and the CRX doesn't. The CRX just has a one-piece bumper cover with more plastic where the metal valance panel would be on the Civic. The fenders are different to accomodate this valance panel on the hatchback. Also, the corner lights are shaped differently. Underneath, though, the Civic and CRX bumpers and bumper supports look to be the same.
You *should* be able to put an '88-'89 CRX bumper cover on a '90-'91 CRX, or vice-versa, but you're going to have to do some extra work to get Civic stuff on a CRX or CRX stuff on a Civic. You'd be flat amazed at how little the cars really share, aside from engines, transmissions, and suspensions!
The *only* issue I can think of with the CRX bumpers is that the '88-'89s use a wider rubstrip on the body than the '90-'91s, and this might be carried over to the molding of the bumper cover. I say "might be" because I haven't had a chance to compare an '88 and '91 CRX bumper lately. So you shouldn't have any trouble mounting the '91 bumper to your '89 CRX, but it might not *look* quite right.
I'm not sure why Honda decided to make so many things different between the Civic and CRX, but they did. Hell, even the front mudguards off the '89 Civic won't go on my '91 CRX! For their own reasons, in '88 Honda made the CRX front body panels different from the Civics' - then they changed them all again in two years! I've noticed the same thing with my '91 Accord Wagon - it uses a different front bumper cover than the '90-'91 4-door or Coupe, and *those* are different than the '92-'93 models.
Frustrating, ain't it?
Mike
skipbudlong
11
Nov 1, 2009 05:33 PM
CORE132
Jun 5, 2009 01:44 PM
Radim
Jun 11, 2008 09:35 PM
CO_CReX
15
Aug 15, 2006 05:15 PM
CalhounBoi
11
Aug 27, 2005 01:08 PM
