16x7, +43mm wheel with 215/45/16 tires, will this rub?
I'm currently running 215/40/16 without any problem.. But thinking about switching to 45 series tires next time around. I heard some had problem with the front rubbing.. Anyone?
Not sure. I'm running 205/45/16 and have had no problems so far. Hopefully someone can answer as I have been thinking about 215's.
nah, you won't have a problem rubbing. i'm running 215/40/16's as well, but on a 16x7.5" rim (43mm offset), and i don't rub....i'm thinking of going to a 215/45/16 as well.
[Modified by R1020, 4:14 PM 8/21/2001]
Those 40 series tires and coilover is just killing me, I mean my stomach.. But it sure looks good when my girl's chest bounce up and down....
yeah, riiiiight.
the 40 series tires are a bit rough, yes. but, think of the steering response . . .
what tires are you running, out of curiousity?
With the Falken Azenis 215-45/16 at full lock I have a very slight rub on the inner fender liner...they are mounted on Mugen MF-10's with a 43mm offset.
Austin
Austin
RP,
I don't think 40>45 series switch will make THAT much difference in your ride. If you really wanna wimp out, you could change to softer springs on your Zeals
hahha, maybe it's just my imagination bouncin...
Yes, I'm thinking about those Falkens.
Kengs: wouldn't softer springs defeat the whole purpose of getting aftermarket suspension?
[Modified by TypeRP, 2:56 PM 8/21/2001]
Yes, I'm thinking about those Falkens.Kengs: wouldn't softer springs defeat the whole purpose of getting aftermarket suspension?
TRP:
what's the springs rates on your sus?
sp00n is claiming 18K F / 16K R is their street spec sus. But that sounds alot like race spec to me
Austin, is your car lowered?
Austin
Austin
Austin
i am running 215/45/16 advan tnr045's on a 16x7 regamaster evo wheel with a 45pcd offset, almost 2" drop. it rubs in full lock on the inside front, which went away when i corrected the camber to something more positive. i cannot comment on the rear because the fender lip is rolled...
RP is running 12k/8k, same as me.
Ben,
Do you know if the TNR045 has been discontinued? I ended up ordering a set of DNA GPs.
[Modified by kengs, 12:20 AM 8/22/2001]
someone else told me the tnr was discontinued as well, but i have no way of confirming. those guys at a&j are on neovas now.
is it true you have a c's shifter? can u contact me please?
Yoshi,
Ben,
Yoshi,
Ben,
18k F and 16k R is way too stiff for street... I was going to run 10k at the rear but dind't want to risk it with the streets we have here... I'm happy with my 12/8 setup.
vitrox
11
Jul 17, 2004 10:30 PM
JohnnyBoy
Mar 16, 2002 10:05 AM
