codes 12 and 21
Old Sep 13, 2003 | 07:58 PM
User 5426's Avatar
Default codes 12 and 21
I have an h22a engine and I am getting codes 12 and 21. I know why I am getting 12 but why 21? VTEC seems to be working perfect.
Code 21 = VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
Modified by SeaQuake at 6:30 AM 9/14/2003
Old Sep 13, 2003 | 08:57 PM
salbaje's Avatar
Default Re: codes 12 and 21 (SeaQuake)
check solenoid screen and try to clean it out
Old Sep 13, 2003 | 09:31 PM
User 5426's Avatar
Default Re: codes 12 and 21 (salbaje)
Do you know where that is located? Thanks in advance.
Old Sep 14, 2003 | 05:39 PM
User 5426's Avatar
Anyone know how to check the vtec selenoid screen and clean it out? Vtec is working fine but I'm just worring about code 21.
Old Sep 14, 2003 | 05:42 PM
hybridEj6's Avatar
Default Re: (SeaQuake)
why dont you pick up a haynes repair manual
Old Sep 14, 2003 | 05:49 PM
User 5426's Avatar
Default Re: (hvacfunded)
I've have a helms manual for the 92-95 eg but no manual for the h22a at this time. I just wanted to know how to do it and if it is easy. I probably will pick-up a haynes manual sometime soon.
Old Sep 14, 2003 | 06:10 PM
poison's Avatar
VTEC solenoids and screens are the same. Just remove it from the engine, and clean the screen using carb/brake cleaner then put it back on.
Pr0ject93hb
Sep 14, 2007 09:50 AM
Type-X
Jul 18, 2007 09:17 PM
ganjasnack
Jun 11, 2007 02:38 PM
Mach69
Dec 23, 2005 01:26 PM
