axle spindle nut removal
Old Sep 13, 2003 | 06:54 PM
elmalouno's Avatar
Default axle spindle nut removal
took this pic cuz i thought i was clever heheh.. any ways these spindle nuts have been a real bitch in the past for me cuz i don't have air tools. so i thought i'd post the best way i have found to get the job done.
for those that don't know whats going on here..i put a screw driver in the rotor to stop it from spinning and the i put my breaker bar on the nut and jacked the mother till it turned.
i have also heard of people putting the bar on the nut and then moving the car so the bar hits the ground and turns the nut that way. i haven't tried that cuz i already had the wheel off.
just thought i'd share.
one more thing.. u should be careful when doing this..
Old Sep 13, 2003 | 07:02 PM
FourthGenHatch's Avatar
Default Re: axle spindle nut removal (elmalouno)
If its on tight than it might lift the damn car off the jackstand and then if it slips it would drop the car down. Horrible idea.
Leave the wheels on, put the 32mm socket on with a breaker bar, big pole over the breaker bar, have someone stand on the brakes, push like bastard. And it should go. But thats was before I had air tools.
If its still hard take the wheel up spray the nut with PB Blaster and heat it up. See if that helps.
Old Sep 13, 2003 | 07:15 PM
xci_ed6's Avatar
Default Re: axle spindle nut removal (FourthGenHatch)
To get the axle out of the hub, hit it once real hard with a 20 lb sledge. do not put anything over the end of it. One or two hit should get it out and won't flare it, putting something over the end just dampens the blow.
-Dustin
Old Sep 13, 2003 | 07:31 PM
elmalouno's Avatar
[QUOTE=FourthGenHatch]If its on tight than it might lift the damn car off the jackstand and then if it slips it would drop the car down. Horrible idea.QUOTE]
what you mean horrible idea.. this **** worked great..
Old Sep 13, 2003 | 09:42 PM
Ef Whore's Avatar
I also think that way seems a little sloppy. My non-airtool method goes like this: 32mm socket/ rachet with a nice 3 foot steel pipe slid over, PB blaster soakdown, and just yank on it. If that doesnt do the trick, than position the pipe a little above horizontal to the ground, and stand on it and hop till' she breaks free. Always works for me.
Old Sep 13, 2003 | 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=FourthGenHatch]
what you mean horrible idea.. this **** worked great.. </TD></TR></TABLE>
But what if your car fell off the jackstands and onto the ground. You would feel like a big dumbass. And it is very possible that could happen by doing that. Especially with rusted axle nuts.
elmalouno's Avatar
Default Re: axle spindle nut removal (Ef *****)
i like this way because it takes almost zero effort... i tried the bouncing thing with the pipe and it wouldn't break.. i weigh about 200 too.... the jack went up the nut snapped.. oh well works for me...
Old Sep 13, 2003 | 10:00 PM
Muckman's Avatar
Moderator in Chief
Works for me...
Ya gotta do what ya gotta do.
Old Sep 13, 2003 | 10:03 PM
elmalouno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">
But what if your car fell off the jackstands and onto the ground. You would feel like a big dumbass. And it is very possible that could happen by doing that. Especially with rusted axle nuts.</TD></TR></TABLE>
what if a tornado came and i flew away?
i am not gunna drop my car on the ground thank u very much..
Old Sep 14, 2003 | 12:13 AM
Vinceg99's Avatar
I never really had any problems with my axle nuts the only time I ever had a problem is when I took off the wheels and had the thing in the air on jack stands and what I ended up doing is putting a board on the rear bumper to the wall of the garage to keep the car from moving. Well on that one I broke the 1/2" drive and my chin smashed into the lip where the fender use to be slit it open pretty nice but then again i wasnt using a breaker bar and I was just pushing down hard as hell on the wrnech learned my lesson real quick grabbed a different ratchet and stood on it...lol
Old Sep 14, 2003 | 09:58 AM
elmalouno's Avatar
Default Re: axle spindle nut removal (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">Well on that one I broke the 1/2" drive and my chin smashed into the lip where the fender use to be slit it open pretty nice but then again i wasnt using a breaker bar and I was just pushing down hard as hell on the wrnech learned my lesson real quick grabbed a different ratchet and stood on it...lol</TD></TR></TABLE>
watch out.. this kids dangerous...
Old Sep 14, 2003 | 10:34 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">watch out.. this kids dangerous... </TD></TR></TABLE>
Dangerous?? Nah thats my tools not me.
Old Sep 14, 2003 | 10:58 PM
solman74's Avatar
That's ok. My stock axles nuts on my Hatch didn't want to come off. I broke a freakin heavy duty tork bar while standing on it trying to break it free. I ended up just cutting them right off and having a nice day.
ricerodder91EX
33
Apr 14, 2007 12:24 PM
RCautoworks
48
Nov 27, 2006 12:26 AM
rasta420
24
Oct 11, 2004 03:09 PM
20lb.teg
Oct 8, 2002 09:13 PM
krazy
Aug 1, 2002 07:28 AM
