B16a question
Old Sep 13, 2003 | 04:53 AM
solman74's Avatar
Default B16a question
Ok, I'm on the last of the wiring. Been at this all night. Has port has listed a Noc sensor. On the Hybrid page there is no Noc sensor listed. I've compared the two wiring harnesses. Zero differences at this point. Can somebody confirm the Noc sensor or disprove it. I have a B16a1 si-r 1
Old Sep 13, 2003 | 09:50 AM
ATS_Antone's Avatar
Default Re: B16a question (solman74)
b16...obd-0 pr3 or pw0 ecu's need a knock sensor to run properly. Or you can buy one of the $$$$ aftermarket ones to void knock sensor out
Old Sep 14, 2003 | 11:47 AM
solman74's Avatar
Default Re: B16a question (antone)
Where is the Noc sensor? I've filled in all the stupid plugs on the motor. I never found it? Do you know where it's located?
Old Sep 14, 2003 | 09:11 PM
B16ED4G's Avatar
rear of the engine near the oil filter, has two pins for the connector
i might be wrong, but i thingk the connector is green
Old Sep 14, 2003 | 09:23 PM
andrew dc's Avatar
Default Re: B16a question (B16ED4G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16ED4G &raquo;</TD></TR><TR><TD CLASS="quote">rear of the engine near the oil filter, has two pins for the connector
i might be wrong, but i thingk the connector is green</TD></TR></TABLE>
you got it... under the intake manifold, near the oil filter... its green!
Old Sep 14, 2003 | 09:30 PM
solman74's Avatar
Default Re: B16a question (andrew ef)
Ok, then. I left it as is. I've not no more C.E lights. I had the two wirings for the TDC backwards which was creating the rought idle. Also my plug wires were not making a very good connection. So I pulled them apart and adjusted the wiring inside the plug to make better contact and Boom I have working no codes B16 motor. I've done it in 3 days. Yipee. Now on to wiring more simple things like an oil gauge and A/F gauge. he he. Also wiring in a tach since I can't see the RPM's
bb4socal
Feb 25, 2006 03:46 PM
sirex89
Feb 4, 2006 01:30 AM
speedracer9k
Jul 28, 2004 09:39 AM
endlesswinterco
Jan 3, 2004 10:41 AM
buzz_worthy321
Nov 23, 2002 02:21 PM
