Explain my 99 Qccord transmission to me
Old Sep 13, 2003 | 12:57 AM
georgeda's Avatar
Default Explain my 99 Qccord transmission to me
My 99 Accord 4 cyl has a four speed trans. I am pretty sure it is not an overdrive - it runs at 2,500 rpm in fourth at 70 mph . My son has an 89 4 cyl that definitely has 4th gear as an overdrive - there even is a circle around the D on the console. If it is not an overdrive why did Honda design it this way?
Old Sep 13, 2003 | 07:01 PM
accord91lx's Avatar
Default Re: Explain my 99 Qccord transmission to me (georgeda)
ok. yes. your tranny has overdrive. listen for it. its like the half shift after it reaches 4th gear... get out on the highway.. you'll hear it.
Old Sep 13, 2003 | 09:31 PM
Stripped Honda's Avatar
99-0104
Default Re: Explain my 99 Qccord transmission to me (desolate)
why the he was just asking a question not like he was asking if the altezza lightbulbs be brighter then stock ......
yeah it has overdrive honda just switched the style shifters that they use to encourage you to drive in overdrive all the time sence it has a more advance transmission that can supossedly sence when to go into overdrive and when not to
Old Sep 13, 2003 | 09:47 PM
1998hondaaccord's Avatar
i have the same car it runs @ the same rpm's at 70mph .
Old Sep 14, 2003 | 09:26 AM
georgeda's Avatar
Default Re: Explain my 99 Accord transmission to me (Stripped Honda)
When the overdrive engages will I see a decrease in the RPM? At what speed does it change to OD?
Old Sep 14, 2003 | 10:52 AM
Chiovnidca's Avatar
Default Re: Explain my 99 Accord transmission to me (georgeda)
Check the gear ratios in your Helms. Both 3rd and 4th are overdriven. It also has a lock-up converter that operates under cruise conditions.
silverbullet9626
Honda CR-V & Element
Jan 11, 2019 03:53 PM
Jessica Lumbis
Oct 19, 2014 05:03 AM
ezlead
Apr 27, 2012 09:15 AM
farikanok
Jan 5, 2009 09:03 PM
StoneGirl
12
Sep 16, 2007 11:32 AM
