Damper settings for Tein SS
Old Sep 13, 2003 | 12:24 AM
arcticblursx's Avatar
Default Damper settings for Tein SS
What are you guys running? I'm running 12fr/14rr....
Old Sep 13, 2003 | 10:08 AM
eg_nezay's Avatar
Default Re: Damper settings for Tein SS (arcticblursx)
I have the Flex and running them at 8 front and rear.
Also, you might want to check out this thread I did, just to make sure you are setting them right.
https://honda-tech.com/zerothread?id=591021
Old Sep 13, 2003 | 03:32 PM
cool...yah, I just changed my settings to 8fr/9rr..seems a bit softer on the freeway n stuff...still hurts over big bumps though lol
Old Sep 13, 2003 | 05:07 PM
eg_nezay's Avatar
Default Re: (arcticblursx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcticblursx &raquo;</TD></TR><TR><TD CLASS="quote">cool...yah, I just changed my settings to 8fr/9rr..seems a bit softer on the freeway n stuff...still hurts over big bumps though lol</TD></TR></TABLE>
Softer? UhOh... sounds like you need to read my thread.
It should have actually gotten stiffer, I think you are adjusting it the wrong way.
Old Sep 13, 2003 | 05:53 PM
sd_ep3's Avatar
my settings are at 9f-10r
Old Sep 15, 2003 | 06:13 AM
DC2-8888's Avatar
Default Re: Damper settings for Tein SS (SD_ep3)
are using that setting for street..??u have flex or SS??
i'm using 14F and 13R for track it rotates pretty good ....
Old Sep 15, 2003 | 07:44 AM
f1nal zeros's Avatar
OMG, eg neezy, that chat about the settings are confusing as hell. Ever hear the term keep it simple.
Just remember:
Clock wise = hard
Counter clock wise = soft
I have the flex and have the settings set at
14fr 16bk
My friend dan has the SS on his hatch and has them set on 21 fr 21 bk. He is one insane SOB.
Old Sep 15, 2003 | 12:39 PM
lol...I made them softer...since I turned the **** counter clockwise after I turned the **** allll the way to the right(clockwise)
Old Sep 15, 2003 | 12:40 PM
Default Re: (f1nal zeros)
how does he have them on 21/21? Isnt the suspension only adjustable to 16clicks? or does each click=2?
Old Sep 15, 2003 | 03:22 PM
I have no idea, but he has them set on 21. On my Tein Flex it says the max is 24, but I counted as far as 28 1/2 clicks. Like I said, weird huh.
Old Sep 15, 2003 | 04:04 PM
eg_nezay's Avatar
The Flex have 28 clicks starting from its stiffest point.
That DOES NOT mean they are adjustable 28 different ways.
Anything over 16 clicks WILL ruin your damper.
Old Sep 15, 2003 | 04:08 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros &raquo;</TD></TR><TR><TD CLASS="quote">
Just remember:
Clock wise = hard
Yes, BUT, make sure you start from the stiffest point(full clockwise) and start your count from there counterclockwise.
Thats the part thats confusing people.
Old Sep 15, 2003 | 04:17 PM
Default Re: (eg_nezay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_nezay &raquo;</TD></TR><TR><TD CLASS="quote">
That is what is confusing everyone bro. Everyone thinks the higher the number the harder the setting. I look at it this way as well.
The way I found out what was what is by doing a little test.
I open the hatch and turn the ***** all the way to the left ( counter clock wise) and then jumped in the back. The car bounced like hell and was very soft. This is how I found out which direction was soft. I then turned the **** all the way to the right ( clock wise) and then continued to do the same experiment. This time it was stiff as hell and did not bounce. This was how I found out which way was the hard setting.
This was a simple experiment but it proved my point.
Old Sep 15, 2003 | 04:31 PM
eg_nezay's Avatar
The confusion starts from people giving the wrong information or when people THINK its the correct way and dont ask how to do it the right way.
That being said, the higher the number, the softer the settings.Thats why you HAVE TO start from all the way clockwise and the count begins counterclockwise. Plain and simple, no need of jumping in your car.
Old Sep 15, 2003 | 07:14 PM
lol..I got confused while reading the latter post...but its ok now
k...so for a recap..I said I was running 12/14..so what i basically did was turn the **** allll the way to the right (clockwise) then for the rears, I turned the **** counterclockwise(to the left) 2 clicks. For the fronts I turned the **** counterclockwise 4 clics. So with that...my settings are 12/14 then right?
Old Sep 15, 2003 | 11:14 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcticblursx &raquo;</TD></TR><TR><TD CLASS="quote">lol..I got confused while reading the latter post...but its ok now
k...so for a recap..I said I was running 12/14..so what i basically did was turn the **** allll the way to the right (clockwise) then for the rears, I turned the **** counterclockwise(to the left) 2 clicks. For the fronts I turned the **** counterclockwise 4 clics. So with that...my settings are 12/14 then right?</TD></TR></TABLE>
No, you are actually at 2 in rear and 4 in front.
Its like this;
16--15--14--13--12--11--10--9--8--7--6--5--4--3--2--1
soft--------------------------------------------------------hard
______&lt;----clicking counterclockwise ______(full clockwise/all the way)
Modified by eg_nezay at 8:27 AM 9/16/2003
Old Sep 16, 2003 | 08:45 AM
That being said, the higher the number, the softer the settings.Thats why you HAVE TO start from all the way clockwise and the count begins counterclockwise. Plain and simple, no need of jumping in your car.</TD></TR></TABLE>
But jumping in a car can be fun sometimes.
topspeed86
Suspension & Brakes
Apr 20, 2005 07:54 PM
JDM_EH2
Jul 12, 2004 10:59 AM
the_illest_soldier
11
Jan 2, 2004 09:20 AM
RiCE On IcE 2
Jul 20, 2003 06:53 AM
RTW DC2R
Jun 14, 2003 02:30 PM
