soaked floorboard after rain
Old Sep 12, 2003 | 09:50 PM
90civichbsi's Avatar
Default soaked floorboard after rain
ok its been raining here about 4 days straight, ive been noticing my car seems to have alot of moisture in it, not to mention the bad mildew smell after a while...
i went out to my car tonight after driving a bit and felt the floorboard was soaked... does anyone know where this water could be comming from? my sunroof doesnt seem to be leaking. any ideas? this is really pissing me off
Old Sep 12, 2003 | 09:58 PM
4crx4me's Avatar
Default Re: soaked floorboard after rain (90civichbsi)
2G CRX?
Hatch struts. Just like everyone else LOL
Old Sep 12, 2003 | 10:02 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
yeah... there's little sealed holes underneath the carpet in the floor pan, you can see them if you get under the car. Look at the jacking points, and then about 4 or 5 inches behind those (towards the center of the car) you'll find the holes. About an inch or 2 in diameter. Caulk em up... it's easy.
Old Sep 12, 2003 | 10:16 PM
Default Re: (VashTheStampede)
btw its a 1990 civic si hatchback... i only notice a leak on the drivers side floorboard and occaisionally the left side of the trunk has some water standing in it
Old Sep 12, 2003 | 10:28 PM
sporkcrx's Avatar
Default Re: (90civichbsi)
I have the same problem. I'm going to install tail light gaskets before the main rain starts to come and I believe that's the problem. ******* better not cost much.
Old Sep 12, 2003 | 10:50 PM
4crx4me's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">******* better not cost much.</TD></TR></TABLE>
Hahahaha riiiiiiight. $30.00 for EACH side for a CRX.=$60 + tax LOL From honda.
Do a search, someone on here, makes DIY ones. I never tried em, though.
Old Sep 12, 2003 | 10:54 PM
Vinceg99's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
Do a search, someone on here, makes DIY ones. I never tried em, though.</TD></TR></TABLE>
I made some myself. I went to Walmart and bought that foam stuff in the crafts departments laid the old one on top traced it cut it out works like a charm. The pieces I got were thinner than the original ones so I just doubled them up they seem to be doing fine I havent noticed any water yet??
Old Sep 12, 2003 | 11:20 PM
sporkcrx's Avatar
Default Re: (Vinceg99)
Yea screw OEM, I'll make my own
Old Sep 13, 2003 | 12:43 AM
brian estrada's Avatar
So... anybody know how to fix the hatch leak problem?
I've got it bad, and it just makes your day to look back when it's been raining and see water running down onto your nice infinity coax's in the back.
I tried some weather stripping around the hatch, but that didn't seem to help at all.
Old Sep 13, 2003 | 12:52 AM
4crx4me's Avatar
Default Re: (jchxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jchxcrx &raquo;</TD></TR><TR><TD CLASS="quote">So... anybody know how to fix the hatch leak problem?
I tried some weather stripping around the hatch, but that didn't seem to help at all.</TD></TR></TABLE>
The real quick answer is, it's either the welds where the hatch mounts to the roof or the roof welds under the black strips that run the length of the roof. They need to be re-sealed with body sealer or equivalent..
The repair techniques has been covered a million times, search "leak(s)" or "water" in archived topics.
HTH.
Old Sep 13, 2003 | 12:57 AM
sporkcrx's Avatar
HTH.</TD></TR></TABLE>
Yep, this is what stopped my leaking from the hatch struts. Now just to fix the tail light gaskets.
Old Sep 13, 2003 | 07:20 AM
It just got to the point where I said... **** it, and I tore out the interior. So it's your call. lol
Old Sep 14, 2003 | 07:16 AM
crxcess's Avatar
you think thats bad. I just got in my car yesterday morning, started, put it in 1st, let off the clutch and water came out of the dash! from under the vent to the left of the steering wheel. water ran down the fuse box cover and down my leg! MY CAR PEED ON ME!
Old Sep 14, 2003 | 05:00 PM
crexer's Avatar
Default Re: (crxcess)
As for the leaks on the floorboards check all rubber grommets in the firewall and if you cut any holes in your firewall for speaker wires or anything that will need to be sealed up also
Old Sep 14, 2003 | 05:24 PM
dankbudz11357's Avatar
Default Re: (crexer)
mine'll leak every now and then, no interior so i decided to deal with it
SeraphimKidd
Feb 16, 2009 10:07 PM
efsedanfan
14
Nov 10, 2008 03:33 PM
Wasabithegosu
33
Jun 21, 2005 01:35 PM
djdizzo
Jan 22, 2005 04:10 PM
Disco Monkey
24
Apr 6, 2004 06:47 PM
