hard to go in first
Old Sep 12, 2003 | 08:53 PM
SIMATIC's Avatar
Default hard to go in first
i got recently bought a 98 accord. i began to notice lately that when i put the clutch in from neutral to 1st, i have to give it an extra nugge to get it in. but if i went to any gear and went to 1st, it would go in smoothly. and also when im comming to a stop i pu the clutch in and go to remove the shifter from a gear(usually 2&3) it kinda feels like the clutch is still sticking to it. any ideas? thanks alot. its got all highway miles on it and the shifter still feels new, heck the car looks new! i dont see it as a problem, i just hope its not the beginning of one thanks alot for the help..
98 accord ex 129k seriously, runs like it has 50 k on it.
Old Sep 12, 2003 | 09:26 PM
RacinMasonC's Avatar
Default Re: hard to go in first (SIMATIC)
well lets see nothing with the clutch assembly touches the shifter... so thats out of the way.. and when your slowing down don't stick it in first till your almost completely stopped or else yes it'll be hard to go into it.
Old Sep 13, 2003 | 03:39 AM
92 ex-r's Avatar
Default Re: hard to go in first (ZiviCase)
Could be the syncro's in the tranny.
Old Sep 13, 2003 | 09:03 AM
vtec fan's Avatar
I have the same problem In first and no matter how soft I try to shift in third it always grinds. is it me syncros and is it expensive to fix.
Old Sep 13, 2003 | 09:45 PM
dvp95's Avatar
Default Re: (vtec fan)
I dont know what it is, but I used to get ot occasionally in the past on my h22. Havent had it in a while, but all I did was double clutch and it goes right in. If going to first doesnt go in, let go of the clutch, step on it again, then go into gear.
Old Sep 13, 2003 | 11:26 PM
HRDCORD's Avatar
Yeah my accord does that too, but I thought it might have something to do with the LSD.......
Old Sep 14, 2003 | 07:50 AM
briq4's Avatar
Default Re: hard to go in first (HRDCORD)
Change the Tranny fluid, works wonders.
Old Sep 14, 2003 | 08:01 AM
89_LXi's Avatar
Default Re: hard to go in first (briq4)
Also check and see if your clutch slave cylinder is leaking fluid, and that the resivour is full. Common Honda problem if I'm not mistaken. Happened on my moms '94 Accord at around 140-150k miles somewhere (couldn't get into any gears without pumping it a few times).
Also like briq4 said, change tranny fluid. Honda MTF is pretty good stuff
Old Sep 14, 2003 | 05:57 PM
SIMATIC's Avatar
Default Re: hard to go in first (89_LXi)
well im not to worrid bout it not goin into gear, i notice it more when the car is cold than when its warm...i put gear oil in for a few days n mann....i had to force it into gear then..the stupoid idiots at the oil change place put gear oil in b/c the PC said so...then i changed it to honda tranny fluid. and ...but anyways when im almost at a StOP AND TAKE IT OUTTA GEAR I NOTCE IT STCIKIN, NOT MUCH BUT I FEEL IT. EVERYTHNG IS OK, FLUID, .LINES ETC
Old Sep 14, 2003 | 09:17 PM
kleankord's Avatar
you've got LSD? interesting...
yeah i have the same prob in first
Old Sep 15, 2003 | 04:44 PM
SIMATIC's Avatar
Default Re: hard to go in first (kleankord)
i dunno if i got LSD, i dont have traction controll cuz its stick
Old Sep 23, 2003 | 12:50 AM
HRDCORD's Avatar
yeah, jdm tranny too
Old Sep 23, 2003 | 04:42 AM
93CivicSI's Avatar
Synchros', slave cylinder, clutch master cylinder, air in the system, fluid level in tranny.
Old Sep 23, 2003 | 08:07 AM
soodark's Avatar
yeah, mine sometimes doesn't want to go into 1st gear from a stop. Usually after I heat up the clutch a little. I have 60K, should I change the tranny fluid yet?
Old Sep 23, 2003 | 09:56 PM
1slowaccord's Avatar
Default Re: (soodark)
I got both problems in my 95 LX. Its hard to get into first, and when I have it above 4000 RPM (which i usually do) it grinds going into third. Gets annoying.
Devers
12
Aug 18, 2011 05:37 PM
vosoka
Dec 13, 2009 12:39 PM
RedRocketCRX
Apr 20, 2005 02:54 PM
thidthad
Apr 29, 2004 10:21 AM
preluder
May 3, 2003 10:25 AM
