Turbo d16 build UP ADVICE NEEDED (EXPERTS ONLY PLEASE)
Old Sep 12, 2003 | 07:52 PM
GPNY's Avatar
Default Turbo d16 build UP ADVICE NEEDED (EXPERTS ONLY PLEASE)
Hi everyone. I am looking for advice on things I should do for my upcoming turbo D16Z6 motor. Please find below the parts list I have put together and make comments. I have gone through as many posts as I could find on the Topic. I NOW NEED FEEDBACK ON MY OWN SETUP. Please take into account my objectives when answering.
My Setup:
D16Z6 Block
STR BlockGuard (JB welded in only, and will be deck plate honed for straightness.
AEM Hyper 2 Rods
75mm Wiseco Forged custom pistons – Est compression 9.4-9.5/1
Total seal 1.2,1.5, 2.8mm rings (Thicker than stock)
Hondata 2b (Will upgrage to S200B datalog soon)
DSM 450 CC injectors
D16Z6 head – Stage 2/3 port polish. Stock sized valves, stock cam, stock springs, stock manifold, stock TB, ARP STUDS, Honda D16z6 HG sprayed with copper spray.
Home made manifold tubular (1.25-1.5”)
Forced Performance TD05H 18G turbo with hahn racecraft 10CM exhaust housing (internal wastegate) 2.5” Hahn O2 housing eliminator
8”*22**3” Spearco Race intercooler Core
2.5” IC piping (Home made mandrel bent
Goals: Daily driven (Mostly highway). Street Legal (Must pass NY emissions) Would like more passing power… Don’t street race but like to show more expensive cars I can stick with them, and also embarrass ricers (any car with neon or a big wing without a powerful motor to back it up). I want my car look stock except for ITR conversion/rsx wheels (Looking for cheap, discreet, and light 15” 5 Lug wheels!). Possibly AutoX once in a while. Test it out on the drag strip once or twice to see how fast it is only.
Questions I am looking for ideas on: How much HP is this setup capable of RELIABLY. (Car will be well maintained, with Mobil 1 oil only, but I don’t want to constantly change parts around.)
Issues I am still debating and REALLY NEED ADVICE ON:
- Sleeving: I need to know FROM SOMEONE WITH EXPERIENCE. How many PSI stock sleeves/block guard JBwelded in will handle daily with no problems or premature stress failure on pump 92 Octane gas (I’ve heard between 12-16PSI). How much Horsepower will stock sleeves support (Looking to tune hondata to AF of 12.5/13:1 when in boost.)
- Crank Micropolish? How much is it?
- ACL bearings? Yes or No?
- Tranny: 94 DX or 94 SI? LSD or no LSD?
- Exhaust: How much HP is 2.5” good for? I am a bit worried about clearance issues with 3” piping. I do not want rattling! Will 3” actually piping help
With the aforementioned setup, please give me advice as to how much hp I should realistically expect. Please also give me weak spots I should look for and fix in the setup above. Please tell me what the weak links are! The motor is still apart and I have been amassing parts for 1.5 years now. I have almost 2600$ Invested so far (and a lot of time), and do not want to spend more than is necessary to get it running (plus tuning). I will be building the engine myself.
Please shoot me advice or comments so that I can get my project finished. I have read tons on the subject and now I want to have informed, educated, and constructive comments on what are the things I should do to satisfy my objectives. THANK YOU VERY MUCH FOR YOUR TIME! (I figure that if you’ve read this much you know what you are doing.) ;-)
Geoff
Old Sep 12, 2003 | 08:38 PM
M.A.R.C.'s Avatar
Default Re: Turbo d16 build UP ADVICE NEEDED (Gpelsise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gpelsise &raquo;</TD></TR><TR><TD CLASS="quote">STR BlockGuard (JB welded in only, and will be deck plate honed for straightness.</TD></TR></TABLE>
??? JB Welded?!?!??
Old Sep 12, 2003 | 08:46 PM
ek9vboi
Guest
Posts: n/a
hahaha. ok lets get serious. JB weld isnt going to hold it down 4ever. TAKE IT TO A PRO!!! Marc tell him how its done...400whp...hahaha, good luck
Old Sep 12, 2003 | 08:55 PM
M.A.R.C.'s Avatar
Default Re: (ek9vboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi &raquo;</TD></TR><TR><TD CLASS="quote">hahaha. ok lets get serious. JB weld isnt going to hold it down 4ever. TAKE IT TO A PRO!!! Marc tell him how its done...400whp...hahaha, good luck</TD></TR></TABLE>
wtf are u babbling about?
Old Sep 13, 2003 | 04:30 AM
maddog20's Avatar
I would personally run a Y8 headgasket. It is a little thinner. Giving you a littlle bit higher compression. JB weld will not cut the mustard. If under 300 Hp don't worry about the blockgaurd. I'd look into Benson sleeves.
Get the crank micropolished and the whole bottom rotating assembly balanced.
Old Sep 13, 2003 | 06:32 AM
GPNY's Avatar
Default Re: Suggestions
Hi all. Thanks for the replies so far. I chose JB weld because I didn't want to heat stress the block with welding. The temperature and tensile strength ratings are sufficient, as it is submerged in coolant and braced against the sleeves and the block. The STR blockguard was chosen because it has large coolant passages to the head.
With ragards to the thinner Y8 headgasket, the pistons I have are already 9.48 a Y8 Headgasket would yeild 9.75 which may be a bit hard to tune and unforgiving if I get shitty gas.
With regards to bensons sleeves... Roughly how much do they cost? I heave heard 800-900 and that sometimes they sink. Please give me realistic boost/hp numbers on stock sleeves...
Thanks
Old Sep 13, 2003 | 06:59 AM
boosted hybrid's Avatar
Default Re: Suggestions (Gpelsise)
Dont waste your time with block guards, they dont do much if you arent detonating. The d sleeves will hold the power you want to make.
Old Sep 13, 2003 | 07:16 AM
Pritos's Avatar
New User
"STR BlockGuard (JB welded in only" !!!!!!!!!!!!??????
jeebus... weld it in at least. and I dont mean soldered. =P
Old Sep 13, 2003 | 08:21 AM
GPNY's Avatar
Hi again to those that have answered. Please no more comments on the JB welded blockguard. I've read them all already!. If they can use adhesives to hold machine gun receiver parts together, I'm sure that they can hold a blockguard in place...
Boosted Hybrid - do you still do street wideband hondata tuning? The motor should be ready for tuning by... January??? (I don't have that much time to work on it, but want to do as much as possible on it myself...
Old Sep 15, 2003 | 06:33 PM
GPNY's Avatar
up
Old Sep 16, 2003 | 07:07 AM
LoSt is BlaCk's Avatar
use the si tranny, unless sohc motors are pretty cheap, but if you simply want piece of mind have it re-sleeved, it's like insurance! stock (honda brearing will usually work fine! if it is just a street use car i personally would not pay the $800 to resleeve it imo! a good tune job will do the job! 2.5 piping will be fine! your car is not a crazy drag beast! keep us posted on the end result, by the way i have a set up like yours so i would like to know!
Old Sep 16, 2003 | 07:12 AM
VTC_CiViC's Avatar
Default Re: Turbo d16 build UP ADVICE NEEDED (Chpt1onBOOST)
A JBwelded blockguard....... wow.
Ditch the blockguard and tune the car properly, the stock sleeves should have no problem holding over 300whp so long as the cyl. pressures are in check.
Old Sep 16, 2003 | 07:25 AM
kaimo's Avatar
I m running D16Z6 a 400hp with stock sleeves and stock head gasket, no problem. compression 8.5. Planing for 500 hp with stock sleeves and they will hold if engine is tuned right.
Old Sep 16, 2003 | 07:27 AM
VTC_CiViC's Avatar
Default Re: (kaimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaimo &raquo;</TD></TR><TR><TD CLASS="quote">I m running D16Z6 a 400hp with stock sleeves and stock head gasket, no problem. compression 8.5. Planing for 500 hp with stock sleeves and they will hold if engine is tuned right.</TD></TR></TABLE>
Oh really?
Dyno sheets? Pics? Setup? Sounds damn good
Old Sep 16, 2003 | 07:36 AM
kaimo's Avatar
D16Z6
wiseco turbo pistons
eagle rods
stock cam
stock intake manifold
stock valves
comp cams valve springs
stock head gasket
Hestec programmable engine management
580cc siemens injectors
Laki Tuning exhaust manifold
Laki Tuning racing intercooler
Shwitzer S2B turbo
no exhaust (wery good to drive in street)
etc
14 psi 328whp
22-23psi 402whp
thats obout it.
Old Sep 16, 2003 | 07:46 AM
ELSpool's Avatar
Default Re: (kaimo)
those are big number for that boost (14psi)
Old Sep 16, 2003 | 07:56 AM
CivicSoul's Avatar
Default Re: (ELSpool)
Hell yeah those are big #'s for 14 psi. I need to move to estonia
Old Sep 16, 2003 | 09:25 AM
Civic TSI's Avatar
Default Re: (CivicSoul)
OEM rings would be better. 3" exhaust will clear. Si tranny all the way.
And I don't care about dyno numbers, how fast does it ran ?
Old Sep 16, 2003 | 11:07 AM
GPNY's Avatar
Default Re: (Civic TSI)
Good advice, I'll be staying on stock sleeves. I'm looking for about 300 HP.
I can't use stock rings, the rings my wisecos use are thicker...
Old Sep 16, 2003 | 11:20 AM
T-sohctec's Avatar
Default Re: (kaimo)
14 psi 328whp
22-23psi 402whp
thats obout it.
Much props man!!!
I was Hoping to make that ,much HP @ 1BAR but my pipes kept blowing off @ 10 PSI so I just left it there out of frustration.
10lbs 230WHP @ 5500 RPMs (this is when my pipes would let go)
I'll just keep telling myself I could be making 300 at the wheels with 5 more PSI & 2500rpms.
I still don't understand why people think that the D sleeves are gonna fail at 300HP.
Old Oct 10, 2013 | 12:24 PM
estewar03's Avatar
Default Re: Turbo d16 build UP ADVICE NEEDED (EXPERTS ONLY PLEASE)
Am I the only one who thinks that turbo is a little big for a DD car thats not driven hard? Wouldn't you get pretty bad lag with the 10cm housing being that he rarely goes over 5K rpm and only shooting for 300hp?
Oh well. This is similar to my current build so keep updating this often, I'm interested in hearing/seeing more.
Old Oct 10, 2013 | 04:16 PM
blackeg's Avatar
holy crap this thread is over 10 years old.
Old Oct 10, 2013 | 04:26 PM
4drEF's Avatar
Keyboard Humorist
I think estewar03 lives in a rural area.
Had to wait 10 years for ocean to carry his message in a bottle to the interwebs.
Miramax
Sep 16, 2015 01:26 AM
Miramax
Jul 4, 2015 01:22 AM
M.A.R.C.
Feb 9, 2004 02:29 AM
Ragezero76
Jul 2, 2003 10:39 PM
