WHAT DO I NEED TO RUN NITROUS
Old Sep 12, 2003 | 05:19 PM
OneFastGsr's Avatar
Default WHAT DO I NEED TO RUN NITROUS
What all do i need to run my nitrous safer. I have
* 4-1 header
* cold air intake
* full cat back
* VAFC
What all do i need? Like do i need a fuel pressure regulator, fuel pump, injectors if so what kind? I need all the info i can get. Im runnin a nos 50 shot dry kit. I have a 1995 gsr.
Old Sep 12, 2003 | 05:23 PM
jdmotorsports's Avatar
Default Re: WHAT DO I NEED TO RUN NITROUS (OneFastGsr)
for a 50shot i would just get a fbr and gauge. also retard your timing a bit to be safe also.
Old Sep 12, 2003 | 05:48 PM
DK4200's Avatar
Default Re: WHAT DO I NEED TO RUN NITROUS (jdmotorsports)
yeah, get a FPR with gauge and get colder spark plugs and retard the timing a degree or two. i run a 65 shot on my LS with no problems at all.
Old Sep 12, 2003 | 07:41 PM
91tegrals's Avatar
well i would at least go with colder plugs.but for a 50 shot you really dont need to retard youre timing and all that stuff...
Old Sep 12, 2003 | 07:42 PM
MooreBoost's Avatar
Default Re: (91tegrals)
All you have to do is take off the caps lock.
Bump fuel pressure alittle, colder plugs, and maybe retard timing a degree for extra safety.
gmoore
Old Sep 12, 2003 | 07:47 PM
91tegrals's Avatar
ok im not sure but do you really need to retard timing for such a small shot...
Old Sep 12, 2003 | 08:17 PM
J337_UNIT's Avatar
50 shot does not require any of the above..retard timing however 1 degree , 93 octane fuel, and colder spart plugs...that is all for a 50 shot...im spraying a 30 tho and need absolutely nothing...its great!
Old Sep 13, 2003 | 12:47 PM
Default Re: WHAT DO I NEED TO RUN NITROUS (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">50 shot does not require any of the above..retard timing however 1 degree , 93 octane fuel, and colder spart plugs...that is all for a 50 shot...im spraying a 30 tho and need absolutely nothing...its great!</TD></TR></TABLE>
you just contradicted yourself. and your running a wet shot. if you read the post you would see he's planing a dry shot. thus a bump in the fuel pressure would be helpfull.
Old Sep 13, 2003 | 02:45 PM
p1ccoloz's Avatar
retarding ignition isnt neccessary not also i should mention if you do retard it you'll be running on retared ignition all the time and so your motor would be well, retarded... Unless you get an ignition system... For a 50 shot get a set of colder plugs and your set... You may wanna get a test pipe or something cause i've heard of a few guys burning up there cats
VTECorona's Avatar
MOTEC system exhaust y0
Old Sep 13, 2003 | 03:46 PM
OneFastGsr's Avatar
Default Re: WHAT DO I NEED TO RUN NITROUS (VTECorona)
thanks i have bought a straight pipe and what kind of plugs?
Old Sep 13, 2003 | 08:01 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Ive been running a dry 50 shot on my LS for a while on nothing but colder plugs. Stock timing, stock fuel pressure blah blah blah.
For a 50 shot youll be fine with colder plugs.
Old Sep 13, 2003 | 09:22 PM
neo1z's Avatar
Default Re: WHAT DO I NEED TO RUN NITROUS (integra707)
If you want to be 100% safe - grab 2 step colder plugs and retard the timing 2 degrees. Shoot all day. No problems.
nitroaccord105
Jul 18, 2007 12:32 PM
XzIpK
May 13, 2007 07:16 PM
Brett
Mar 6, 2003 08:10 AM
lsteggy
Dec 17, 2002 04:01 AM
