couplers and clamps... where to get them???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid »</TD></TR><TR><TD CLASS="quote">http://www.mcmaster.com
T-bolt clamps pg 207, 5312K12
Nitrile hose pg 196 5285K27</TD></TR></TABLE>
did you mean 5285K37 for the hose instead? or should he go with the 2 3/8" ID?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt B »</TD></TR><TR><TD CLASS="quote">home depot, fernco sewer couplers. The 2 inch ones fit 2.5 od pipe and they come with clamps attached. cheap too.
They're made out of rubber. Try attaching it to the turbo, the heat will deform it and blow the pipes right off
</TD></TR></TABLE>They're made out of rubber. Try attaching it to the turbo, the heat will deform it and blow the pipes right off
How flexible are the silicone couplers? My throttlebody measures 2 5/8 and the couplers come in 2 1/2. Will it stretch enough to fit?
-Ryan
-Ryan
cant believe nobody mentioned Roadraceengineering.com
You can buy couplers in 1 foot pieces and cut your own to save some cash.
They also sell t-bolt clamps too.
Here is a couple sites for you to surf
http://www.partssystems.com/sh...REEZE <-hoseclamps
http://www.dnaparts.com/airtoair.htm <-couplers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup »</TD></TR><TR><TD CLASS="quote">How flexible are the silicone couplers? My throttlebody measures 2 5/8 and the couplers come in 2 1/2. Will it stretch enough to fit?
-Ryan</TD></TR></TABLE>
Can't believe noone mention me
hahahhaha
Actually I am working a deal with SPA for all hoses and reducer, hump hoses coupler and that good stuff...as well as t-bolt clamps, wiggin clamps and etc
I should have pricing in a few days
stan
hahahhahaActually I am working a deal with SPA for all hoses and reducer, hump hoses coupler and that good stuff...as well as t-bolt clamps, wiggin clamps and etc
stan
We used home depot couplers to extend the turbo piping for Cyphear's turbo kit and we have actually had more blow offs with the silicone couplers. Their has been no deformation with the home depot coupler. Note: Only two home depot couplers were used in this in this install, and does not connect to the turbo directly.
I too am searching. Best place I've found for Silicone connectors is: http://www.roadraceengineering...s.htm ...I'm buying 2 ft just to be on the safe side [it's cheaper in longer lengths too] and for the T-Bolt connectors, I'm going with: http://www.partssystems.com/sh...REEZE ...$2.40 ea...can't beat that.
teg racer 877
Mar 4, 2006 07:52 PM
