squealing belt
my alternator belt made a very annoying high pitched noise, so i took it to the shop and they tightened the alt pulley. but now, majority of the time, it makes the same noise on startup, but then stops after a couple seconds. is it just a wornout belt or could be it something else?
Take it back to the shop and tell them to fix it right, if its the alternator belt all you do is loosen the top nut, stick a pry bar in there and pull so it gets tight.
higgunscrx
Jun 15, 2006 05:11 PM
519[H]Si
May 25, 2004 09:25 PM
