Swap finished, Idle jumping up/down, no CEL.
Old Sep 12, 2003 | 04:01 PM
Skyllz's Avatar
Default Swap finished, Idle jumping up/down, no CEL.
Here is the thing.
99 B18C1 with ITR tranny in 96 EK using 96 SOHC Vtec harness and OBD2-OBD1 conversion harness with chipped P28.
Car started right up without a CEL but idle is bouncing between 1700-2000.
All the vaccum hoses are ok, nothing cracked or leaking.
Disconnected the IACV, threw a code and idled between 1500-1600(engine is still cold)
Reset ECU, replug IACV and same thing, 1700-2000rpms idle.
Engine rev real nice when giving it some gaz, does not stutter, bog or whatever.
I cant let it warm up yet since exhaust is not connected to manifold and I'd like to keep my neighbour happy at night... Will do tomorrow to see what happens.
Anywhere I should start looking tomorrow?
Thanks alot for your help!!!!
Old Sep 12, 2003 | 04:15 PM
Hybrid96EK's Avatar
Default Re: Swap finished, Idle jumping up/down, no CEL. (Skyllz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skyllz &raquo;</TD></TR><TR><TD CLASS="quote">Here is the thing.
Here is what I would do to begin with.
First you are going to need to allow the car to warm up completely. Make sure you have bled all the air out of the coolant. If this checks out good then disconnect the IACV. Idle should drop around 400rpms (low). If it doesn't, set it to this point and plug the IACV back in. Turn the car off and then back on. It should idle correctly now with no codes. If it doesn't then I would pull the IACV and clean it up real well. Make sure you have a good tight seal also with no leaks. If after doing all the above you still have an issue then I would say check again for vac leaks.
Old Sep 12, 2003 | 04:18 PM
Skyllz's Avatar
Sounds like a plan, thanks for the advise!!!
Anybody else got ideas to get me going tomorrow?
The more input I have, the less i'll have to come back top post that it still does not work
Old Sep 12, 2003 | 04:27 PM
Hybrid96EK's Avatar
Default Re: (Skyllz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skyllz &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a plan, thanks for the advise!!!
The more input I have, the less i'll have to come back top post that it still does not work </TD></TR></TABLE>
The above SHOULD cover it. The only other thing that worries me is your "chipped" ecu. Its not real likely, but this could also cause idle problems as well. Make sure your IACV is correctly plumbed to the coolant supply/return lines its intended for as well. I had mine run incorrectly and it drove me up a tree for months until I just figured it out.
Old Sep 12, 2003 | 04:29 PM
Skyllz's Avatar
Excellent, I just printed all that to have it under my eyes tomorrow when I reopen the hood
Old Sep 13, 2003 | 08:18 AM
Skyllz's Avatar
update...
Did everything mentionned above, reset the ECU, still same problem but with a twist...
When the IACV is plugged, it will jump 500rpms up and down...
When I unplug it, it'll jump faster about 200rpms.
I tripple checked all hoses and vaccum but could not find anything...
Only thing I have not tried is another ECU but I know this one was working last week in a B16A 95 Civic Si.
Old Sep 13, 2003 | 03:57 PM
ghettols's Avatar
i'm having the same problem with my ctr swap in a 96 ek. what i want to know is how to bleed the coolant system because it doesn't have the neck with the valve sticking out of the head like the ls motor i was used to.
Old Sep 13, 2003 | 04:08 PM
Hybrid96EK's Avatar
Default Re: (ghettols)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettols &raquo;</TD></TR><TR><TD CLASS="quote">i'm having the same problem with my ctr swap in a 96 ek. what i want to know is how to bleed the coolant system because it doesn't have the neck with the valve sticking out of the head like the ls motor i was used to.</TD></TR></TABLE>
Some of the engines won't have the bleeder screw.
Old Sep 13, 2003 | 04:09 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skyllz &raquo;</TD></TR><TR><TD CLASS="quote">update...
Only thing I have not tried is another ECU but I know this one was working last week in a B16A 95 Civic Si.</TD></TR></TABLE>
What ECU is it? A stock Civic Si ecu is a P28, and unless its chipped, it should not be on a DOHC engine. Did you drop the engine in as a complete swap? Change any parts such as the intake manifold?
Old Sep 13, 2003 | 04:42 PM
ghettols's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Some of the engines won't have the bleeder screw.</TD></TR></TABLE>
how would you go about bleeding then?
Old Sep 13, 2003 | 05:08 PM
Hybrid96EK's Avatar
how would you go about bleeding then?</TD></TR></TABLE>
Put the cap on to the first locking position, run the car until it reaches operating temperature and the fan comes on twice, shut the car off and check the level.
Old Sep 13, 2003 | 05:10 PM
Skyllz's Avatar
What ECU is it? A stock Civic Si ecu is a P28, and unless its chipped, it should not be on a DOHC engine. Did you drop the engine in as a complete swap? Change any parts such as the intake manifold?</TD></TR></TABLE>
No parts have been removed except for the TB and I changed the gasket.
The ECU is chipped and running a P30 program(meant for a p28 but P30 fuel maps) and I tried it in another car today, working A1.
After driving the car a little today, it's getting intermitent now, sometimes it'll go down to 1000 and stay there, other times it'll go between 1000-1500rpms...
Oh well, i'll leave it like that until I feel like fudging with it, now I want to enjoy my car
Old Sep 14, 2003 | 10:43 AM
Nick H's Avatar
New User
i've had similar problems with my h22 swapped accord...but i was wondering if this would have anything to do with an auto ecu on a 5 speed...someone mentioned this a while back...but i will give that IACV a try and see if it checks out as well...
Old Sep 14, 2003 | 05:51 PM
Audi RS4's Avatar
Lover
Default Re: Swap finished, Idle jumping up/down, no CEL. (Hybrid93Eg)
First you are going to need to allow the car to warm up completely. Make sure you have bled all the air out of the coolant. If this checks out good then disconnect the IACV. Idle should drop around 400rpms (low). If it doesn't, set it to this point and plug the IACV back in. Turn the car off and then back on. It should idle correctly now with no codes. If it doesn't then I would pull the IACV and clean it up real well. Make sure you have a good tight seal also with no leaks. If after doing all the above you still have an issue then I would say check again for vac leaks.</TD></TR></TABLE>-/
i'm intrigued about the coolant thing...........if there is air in the cooling system the IACV will not function properly? please go into a little more detail
Old Sep 14, 2003 | 05:53 PM
Hybrid96EK's Avatar
Default Re: Swap finished, Idle jumping up/down, no CEL. (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">-/
i'm intrigued about the coolant thing...........if there is air in the cooling system the IACV will not function properly? please go into a little more detail </TD></TR></TABLE>
Air = hotter then then coolant. So if air is trapped in the system and it hits the valve then it will cause it to close even more then it already is. Takes only a second for the air to pass, unless the bubbles get caught, so it can't cause your idle to go up and down.
Old Sep 14, 2003 | 09:32 PM
ghettols's Avatar
thanks man, i bled the system and cleaned the screen on the iacv just for extra measures and the idle is now back to normal...good looking out.
Old Sep 18, 2003 | 03:35 PM
Skyllz's Avatar
Ok... still doing it and it's starting to bug me BAD...
What i've done so far...
-purge system to make sure there are NO bubbles anywhere.
-looked for vaccum leaks...
-switch ECU with a known good one
-readjust idle as per manuals, cant get it to idle lower then 1100 even with idle srew fully in...
-when I unplug the IACV idle goes to 1100 and purrs like a kitten
-Did I mention I looked everywhere I could for vaccum leaks?
-Nothing except the TB and the IACV has been tampered with on the intake.
-the TB gasket is new
-the IACV o-ring is ok, I added a slight coating of sillicone to make sure.
-All ground are excellent(1 on head, 1 on tranny, 1 on intake manifold)
-Still no CEL except when I unplg the IACV.
-Remove T-fitting from manifold to FPR and IAB, now only 1 tube straight to FPR.
-Cursed alot...
Anything else I forgot?
Next step is to try another IACV(found one tonight) otherwise I'm clueless... BAD...
Any other vaccum nipples on a GSR manifold except lower driver side where FPR/IAB connect, behind where brake booster connect and close the the TB flange poiting to the firewall...
HELP...
Thanks
dev
Dec 5, 2010 07:52 PM
Teaser
Apr 23, 2007 08:32 PM
kwazigoku
Apr 1, 2007 10:41 AM
Skyllz
Sep 18, 2003 04:59 PM
