J1 VS Y!
Old Sep 12, 2003 | 11:43 AM
Slvr_CRX's Avatar
Default J1 VS Y!
Whats the differnce between the j1 and y1 tranny? when i'm putting it into my crx? I have a b16a J1 tranny into a 91 crx hf? Thanks
Steven
Old Sep 12, 2003 | 11:58 AM
b16cr-x's Avatar
Default Re: J1 VS Y! (Slvr_CRX)
The gear ratio's are different, and the Y1 was available with LSD. Check out this link for the ratios.
http://ff-squad.com/Bgears.htm
Old Sep 12, 2003 | 12:27 PM
SiRex91's Avatar
Default Re: J1 VS Y! (b16cr-x)
The J1 has shorter gears than the Y1.
Old Sep 12, 2003 | 02:53 PM
HandCommand's Avatar
Default Re: J1 VS Y! (SiRex91)
The Y1 is geared a little taller since the CRX is lighter than the DA Integra XSI. The S1 and J1 were geared shorter to get the heavy weight of the Integra moving. The Y1 was offered a OEM LSD. The S1 and J1 were not. The YS1 that came in the JDM Integra XSI's were offered OEM LSD, but not until the later years of that generation.
I would run a S1 or J1 (Integra trannies) in a CRX, but I would never run a Y1 (CRX tranny) in a DA Integra.
But.......I would rather run a Y1 tranny in an Integra with a high revving B16 RATHER THAN running a "A1" U.S. LS tranny with the B16.
YUCK! Ive seen some people just buy a B16 engine and couple it to their U.S. cable LS trannies. The B16 has no torque for that kind of long gearing!
Old Sep 12, 2003 | 05:47 PM
misfithamster's Avatar
Default Re: J1 VS Y! (HandCommand)
just got my car back today from the shop and my b16 came with a j1 and its geared short as hell dude. 70mph im perfectly hittin 4000rpm, although it seems pretty comfortable up there. seems good for acceleration though.
Old Sep 12, 2003 | 09:44 PM
Ef Whore's Avatar
Default Re: J1 VS Y! (misfithamster)
S1's rock.
Old Sep 12, 2003 | 09:47 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Re: J1 VS Y! (Ef *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">S1's rock.</TD></TR></TABLE>
haha.. Amen. Go S1 crew!
Old Sep 12, 2003 | 10:19 PM
b16_madman's Avatar
J1's rock.
Old Sep 12, 2003 | 11:40 PM
solman74's Avatar
Default Re: J1 VS Y! (B16_madman)
How you check to see if your Y1 has the lsd? I got a Y1 with my B16a which is going into a EF hatch. I was just curious if I could run the number and find out. It's still got the sticker on it and everything.
Old Sep 12, 2003 | 11:45 PM
Red_Si's Avatar
Default Re: J1 VS Y! (solman74)
you can look through the little hole in the tranny and if there is a bar its non lsd, if there is no bar you have an lsd tranny
Old Sep 12, 2003 | 11:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solman74 &raquo;</TD></TR><TR><TD CLASS="quote">How you check to see if your Y1 has the lsd? </TD></TR></TABLE>
Don't pay any attention to numbers or the letters "LSD" stamped on the case. There are many scammers out there.
You could pull an axle out and look through the hole. There should be no "bar" in the middle. If you are pulling out only one axle, you should the other end of the INTERMEDIATE Shaft, or if you pull the Int. Shaft, you should see the end of the Passenger side axle.
Or if you pull both, you should be able to see right through.
If the tranny is already in the vehicle and filled with fluid, you dont want to check it this way.
Instead do a burnout and look for both tire marks.....
Or you could lift the drive wheels up in the air. ENGINE OFF. Put it in gear.....and spin one side with your hands. The other tire should spin in the same direction, not opposite like in a open diff tranny.
Old Sep 12, 2003 | 11:50 PM
solman74's Avatar
I staired at that damn whole the whole freakin time I was cleaning. There was no bar. I mean when I got the motor it was so dirty it took me 2 days of cleaning it. I bet your wondering why I didn't have it hot tanked. That will be done when I rebuild it next year for my turbo. I plan on tearing the whole thing down. Hot dog I have the lsd trani. I wonder who I got so lucky. he he. **Smiles with joy**.
Old Sep 14, 2003 | 10:20 AM
4potnick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandCommand &raquo;</TD></TR><TR><TD CLASS="quote">The Y1 is geared a little taller since the CRX is lighter than the DA Integra XSI. The S1 and J1 were geared shorter to get the heavy weight of the Integra moving. The Y1 was offered a OEM LSD. The S1 and J1 were not. The YS1 that came in the JDM Integra XSI's were offered OEM LSD, but not until the later years of that generation.
!</TD></TR></TABLE>I would think that y1 tranny would go great for a boosted vtec motor. Anyone ever use one of these for a turbo application?
Old Sep 14, 2003 | 11:12 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">J1's rock.</TD></TR></TABLE>
b16a and J1 = fun
crxdxsir
Mar 28, 2007 04:22 AM
spcrxracer
Jun 2, 2004 07:41 AM
twin rex's
Mar 12, 2004 07:01 PM
spooned out
Aug 26, 2003 06:56 AM
whitemike1644
May 2, 2003 11:02 AM
