B18c into EF si..... which AC bracket will work?
Old Sep 12, 2003 | 10:12 AM
Charlie Moua's Avatar
Default B18c into EF si..... which AC bracket will work?
I might just be keeping AC.... I highly doubt it though
But I just wanted to know if I were to keep my ac with my B18c swap with ac bracket will work with our AC system? I know the EG can use a Delsol bracket....
hasport or another option.
Old Sep 12, 2003 | 10:38 AM
EL Vap133's Avatar
Default Re: B18c into EF si..... which AC bracket will work? (Charlie Moua)
Place Racing has a bracket too. I believe you can use a Honda bracket (not sure which one) but you have to modify it I believe.
Old Sep 12, 2003 | 10:53 AM
I Want An Si's Avatar
you have to use a place racing or hasport bracket.....
with place racing it only works with the SANDEN compressor
if youve got a Matsushita.....your only option is Hasport bracket(works for both)
you cannot use any stock brackets as it makes the compressor sit tooooo low and itll hit the crossmember regardless(even if youve got a z10 or jimfab)
youll probably also want to get a slim fan as well.....
oh yeah im talking from Experience
Old Sep 12, 2003 | 11:03 AM
EL Vap133's Avatar
Default Re: B18c into EF si..... which AC bracket will work? (I Want An Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Want An Si &raquo;</TD></TR><TR><TD CLASS="quote">you have to use a place racing or hasport bracket.....
there you are joto!
oh yeah im talking from Experience</TD></TR></TABLE>
Old Sep 12, 2003 | 11:39 AM
b16_madman's Avatar
http://www.hasport.com
i gots one, good stuff. i even cracked mine and they sent me a new one. Fitment is tight. but it fits.
You don't need slim fans, but if you got the $ I'd go ahead and get a pair for the thing.
Old Sep 12, 2003 | 02:56 PM
HandCommand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">I might just be keeping AC.... I highly doubt it though
hasport or another option. </TD></TR></TABLE>
Charlie, contact me if you are interested in the HaSport A/C bracket. I have them in stock. (and Im in your neck of the woods)
Old Sep 12, 2003 | 04:22 PM
Swift's Avatar
Default Re: B18c into EF si..... which AC bracket will work? (HandCommand)
hey, handcommand, how much do you sell for? Any kind of HT discount?
Old Sep 12, 2003 | 05:24 PM
Tony.... i've been trying to contact you about a lot of questions with my ef because i know your the local expert with ef and swap info. I've been so freaken busy that i have not gotten a chance to call you. I work 85hour a week so you get the idea. we should sit down and talk some time about possiblity of you helping me wire up my car to OBD1.. LOL
Old Sep 13, 2003 | 07:20 AM
SuperCivic's Avatar
like everyone has said, only the hasport bracket will work for you. another thing to think about is clearance between the exhaust manifold and the a/c condensor. i have a b20 in crx (basically the same as ef w/ b18) running a stock honda b16 manifold and it's really tight. the stock heat shield won't fit. if you run jdm 4-1 headers you might have issues with this.
Wes V
Sep 3, 2005 09:08 AM
Wazup
Jul 8, 2002 06:57 PM
